DO you leave your gray valve open? DON'T. For now,, I'd you might try this.
Plug drain. Dump tank (Gray) Disconnect hose.. Stuff a can of fogger up the pipe and put the crain cap on. Come back in 2 hours and remove the can, close the valve (in the opposite order) that should gas 'em.
NOTE> might be a good idea to be elsewhere for those two hours.
