Caulk
bsport
Help in what type of sealer to use on slide outs old stuff is starting to pull paint off and dried out. Tried to fine TremPro 645 toured a RV manufacture in Elkhart In and that is what they were using, any other type you would recommend.
Thanks Bsport
3 REPLIES 3
SH
Lots of good sealants available. Sika makes several good ones. 221 is a great general purpose polyurethane sealant...great elasticity as well. 505UV for use around EPDM.
Trempro also has 635 as another good option.
I have also used Chemlinks M1 with good results.
A good polyurethane, tripolymer or polyether should do the job!
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
westend
Geocel tripolymer is what's on my rig.
'03 F-250 4x4 CC
1492
Moderator
Moderator
Moved from Forum Technical Support
