Caution
down_home
The Ford Dealer sent our Ford Edge St to Sun Valley Bumpers to install the towing gear. Bad experience all around, I won;t go into except....they did not even try to adjust air brake cylinder.
Result pulling away, after from the RV wash after hooking up the rig started jerking and then we saw smoke from the Edge.
The front brakes were on fire.
Too it back after unhooking and makign sure everything was operating properly to Sun Valley...They said make an appointment. That would mean at least a week wait.
Took it to Trotters and he set it up properly and it worked fine. now on the way out of town near Seligman, stopped the rig to use the facilities. Started back up and about the time we reached the exit smoke from the Edge's tires.
Four tires all destroyed with parts of the threads around the axles.
It had electronically shifted into park.
Sitting at Ford right now. Seems this is a problem with other edge STs.
If Ford can't or won't fix it...will they replace it with one we can agree on and not lose any money.
27 REPLIES 27
CA_Traveler
PastorCharlie wrote:
Friend couple that we convoy with across the USA left my home on one visit and I noticed two black lines out my driveway and down the highway. I chased them down and and stopped them. Sometimes people forget to move the cars out of park when they begin to tow.
And I'm sure some forget to put them in park as mine requires. :S
2014 Grand Cherokee Overland
Bob
Grit_dog
Navigator
Navigator
Sorry to hear of the issues, but this is a classic case of needin to have some knowledge of what youโ€™re operating and responsibility to check proper operation and the ability to understand and maintain, or be at the mercy of others.
Tough spot though, hope you get the best possible resolution.
Two_Jayhawks
down home wrote:
Well, We are stranded. Ford took five days and they say it is ours and Sun Valley's problem. We have no receipts. Ford paid for it. Sun valley doesn't know what they are doing and we can't move the car from Ford's lot..until tires are put on..and they did not send State Farm photos requested so they will cover the tires. Then the coach,the transfer switch quit. 4 to 6 days and find someone to install it. Another 500.00+ plus. Wife is about to collapse and I may not be far behind. Never buy another Ford and that is about every auto we have bought.
Been driving Fords almost exclusively for 40 years & been very pleased. Still pull my 2014 Edge. But I won't be buying a Ford to use as a toad any time soon.
Bill & Kelli
2015 DSDP 4366 pulling a 21 JL Unlimited Sport
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
PastorCharlie
down_home
Executive45
1. Bought Edge at Dealer.
2. Sun Valley installs towing equipment which fails.
3. Took back to Sun Valley but because you couldn't wait, took it to Trotters
4. Failed again, this time because of transmission.
Ford will say it's Sun Valley's fault; Sun Valley will blame Trotters because you took it to them so they have no documentation as to what was wrong, if anything; Trotters will say it's Ford's fault because they did it correctly; So back to Ford. Repeat process again. I'd say it's a pretty perfect circle....Good Luck. I feel your frustration and pain in the wallet.
Part of the "deal", written into the CONTRACT with the dealer I purchased the Equinox from, was that they would install the towing equipment and I would be allowed to inspect it, including torquing the bolts, prior to the car being put back together. This eliminates any and all confusion later on should something go amiss. This post also highlights the importance of having a tire pressure monitoring system that also includes tire temps.....Dennis
down_home
The brake problem was rectified...However the transmission electronically shifted into park when we started out after stopping later and destroyed the tires.
Service Mgr said it was the Bumpers whatever and no Fords. He had my wife confused, deliberately I think. he called her instead of me and she did not call me. Wife is stressed out as I am over 70,000.00 on vehicle and RV repairs this trip including the new Edge.
So they didn't provide a vehicle and wife broke down and didn't call me so we sit here at a Relatives. And. I'm not sure I can handle this bad situation with Ford, after all we have been though, without coming unglued.
CA_Traveler
Good point and not clear. First time the front brakes were on fire. Aux brake problem?
Second time all 4 tires destroyed and it was in park and is a known Ford problem.
If it's a Ford problem can they wiggle out of it for say improper setup or something else? Based on my tranny experience they will try. Document and take pictures of everything. Have a very complete detailed log for you. Use it and don't give them conflicting information.
Ford did successfully fix my tranny only when I gave them the details on their boched repair. And it was driven hard for 250K miles before he sold it.
Bob
BobGed
I think the OP is asking about the fact that the Edge automatically shifted into Park.
In any case, as a previous poster said, that's something he will need to work out with Ford, and probably not at the dealer level.
2017 Tiffin Phaeton 40QBH
2014 Jeep Cherokee Limited
CA_Traveler
Cliffs Welding in Mesa has a reputation for quality expensive work for this type of installation.
Bob
CA_Traveler
Not sure why you went to Ford but I'd expect them to deny all responsibility and suggest you contact the bumper guys.
In 2004 I (and others) was having a problem with a box brake. I installed a brake light on the towed dash that was visible in the rear view mirror. The problem was resolved but it took time. Current rig has a cab brake light that is activated by the toed brakes, but no issues since the fix and no longer have a box brake.
Keep us informed but I doubt Ford will fix it and certainly they won't replace it.
Bob
Horsedoc
Not clear on what happened exactly. Is it not your responsibility to make sure your air brake cylinder is adjusted correctly?
Or am I missing something?
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
PastorCharlie
No one but the Ford dealer can answer that question.
