Damp Rid in Refrigerator
calewjohnson
Defrosting the fridge today...just curious, can I use Damp Rid in the fridge to keep moisture down so the bottom portion of the fridge doesn't ice up (think of the silver stack in the fridge). We are full-timing, would like to keep from having to do this every other month or so.
Thanks.
Cale
TV: 2015 6.7 F350 CC LB 4x4 DRW with 14k GVWR option (4.3 gear), 98 gallon aux tank installed by Transfer Flow
New: 2014 Voltage 3950
Traded: 2014 Outback 323BH
Still Have: 2007 Fleetwood Nitrous 23ft Toy Hauler
6 REPLIES 6
calewjohnson
Thanks for the replies. I emptied the fridge out this morning and let it sit open all day. All dried up, she is good to go. I will look into a fan as suggested. Thanks all for the info.
Cale
GordonThree
What kind of Damp Rid are we talking about? The kind I use is in a great big bucket, it sits in the sink over winter. It's just calcium chloride salt which is the actual desiccant and then some sort of absorbent polymer pellets (plastic) to soak up excess water when the calcium gets the sweats.
More info:
DampRid MSDS
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
doxiemom11
Don't think it's safe around food.
We_Cant_Wait
Only problem with the Damp Rid products is the small, it's quite chemical and your food might pick up the smell.
GordonThree
Worth a shot Cale, maybe try one of the hanging-packet kind, so there's no risk of it tipping over and making a mess.
I'm guessing the water vapor will still prefer to condense on the very-cold heat exchanger (the silver stack), rather than in the chemicals of the damp rid.
720Deere
The better bet is to put a fan inside the refrigerator to circulate air. I get virtually no ice on my coils now that I have a fan moving the air across them. The fan also increases the cooling capacity of the fridge.
2011 Ford F-350 4X4 CC LB SRW 6.7
2013 Keystone Fuzion 315
B&W Companion Hitch
1 wife 2 kids and 1 dog
