Jul-24-2018 06:19 PM
Jul-25-2018 06:02 AM
eHoefler wrote:
The bars are not rated for the tongue weight. They are rated for how much weight they can transfer. The bars are more than adequate. If you have a 750 pound tongue weight, the bars will transfer 600 pounds to the steer axle and trailer axles leaving 150 pounds on the ball. The bars are correct.
Jul-25-2018 05:25 AM
Jul-25-2018 04:55 AM
Jul-25-2018 04:40 AM
Jul-25-2018 03:58 AM
shades9323 wrote:
Perhaps I will call around to a few Jayco dealers and see what they would install.
Jul-25-2018 03:15 AM
Ralph Cramden wrote:
600 lb bars is probably correct. You are better off using 80 to 100% of the bars spring rate than if you had 1000 lb bars and used 40 to 50%. The more spring rate used as a percentage with an Equalizer brand hitch, the more anti sway control it has by design as its based on the amount of friction at both the head and rail bracket, the more spring rate, the more friction. The 23B also has, or had, only a 3" tube for the A frame members, which might not be the best to use a heavier bar with.
Unfortunatly Equalizer does not have an 800 # bar option and you're at the border between the 600 and 1000#. By going to 1000# bars you might end up with one rough riding SOB by the time you dial in enough rate to make the sway control effective.
Not all dealers happen to be morons when it comes to setting up a WDH. Chances are the dealer, since he is a Jayco dealer and an Equalizer dealer, has set up more than one X23B before and knows a little more than us experts here on that specific application. Especially when taking into account the setup will be completely different from tow vehicle to tow vehicle with the same trailer.
The ultimate question would be "Did the hitch restore the front ride height of the tow vehicle when adjusted to Equalizers specs, and how does it tow and feel when loaded for use"? If all is good, why would you change?
Jul-25-2018 03:00 AM
nohurry wrote:
....and I would bet equal-I-zer over-engineered a bit. .
Jul-25-2018 01:30 AM
Jul-25-2018 12:46 AM
Jul-24-2018 09:42 PM
Jul-24-2018 09:28 PM
Jul-24-2018 08:02 PM
SoundGuy wrote:nohurry wrote:
IMO, you’re fine. Jayco lists unloaded hitch weight at 365#. It’s a lightweight trailer, and I would bet equal-I-zer over-engineered a bit.
Disagree. The OP's 2015 X23B offers a mere 1045 lbs CCC even before anything including a battery is added to the trailer. With a GVWR of just 4950 lbs his challenge will be to keep the trailer's GVW, loaded & ready to camp, within that 4950 lb limit. At an average 13% gross tongue weight to gross trailer weight he could easily see this trailer's gross tongue weight average in the 650 lb to 700 lb range. To answer the OP's question - yeah, I'd move up to 1000 lb spring bars but that will require a new head as well.
Jul-24-2018 07:54 PM
Jul-24-2018 07:46 PM
Jul-24-2018 07:14 PM
SoundGuy wrote:sgip2000 wrote:
The hitch head is the same for most kits.
Not for the Equal-i-zer ... if the OP moves up to 1000 lb spring bars he has to change the head as well.
