โJul-26-2015 05:57 PM
โAug-03-2015 09:48 AM
j-d wrote:
Well, let's see. In a panic stop, a 4000-lb car presses against the towbar in the way the towbar was designed to work. And hopefully with not all that much pressure since the toad should have a supplemental braking system.
But when the rig backs up and the front wheels of the toad jam into their stops, a 14000-lb motorhome presses the towbar in a crooked way that it wasn't designed for.
And, oh, the same thing happens to tie rods, tie rod ends and rack/pinion in the toad.
โAug-02-2015 05:54 PM
โAug-02-2015 05:00 PM
โAug-02-2015 04:35 PM
โJul-28-2015 04:49 PM
gasser9 wrote:
The caster angle is set to go FORWARD not back the front wheels cramp in one direction or another & bend the towbar. I f they don't cramp off you can back forever but usually 3 to 10 feet they will cramp resulting in buying a new tow bar. If you can find someone stu*** brave enough to steer the toad be sure to stat it so the power steering helps. Do not pot thumbs inside the wheel so when it cramps they will not be broken.
โJul-28-2015 01:37 PM
Katy Did wrote:
I am taking all into consideration will probably not reverse unless in a problem situation. I am thinking of just putting it on my Big Tex. It fits. I use the trailer for my motorcycles or my trike. Just a huge hassle using the trailer in my opinion, but I may. I have been looking at wheel tie downs. Any suggestions for that size tire? I've been on Amazon looking around.
โJul-28-2015 01:03 PM
โJul-28-2015 12:18 PM
Katy Did wrote:
Ok. I am a newbie. I am considering towing 4 down. I have a couple of simple questions.
1. I am reading that I will be unable to back up a 4 down tow. Can anyone tell me why? I know, may be a simple answer, but if the car is in the neutral, why can it not be backed up?
2. I have a 2013 Smart Car. I am getting feedback I am unable to tow it, so I am considering trading it in for a Chevy Malibu. Any thoughts from those that are experienced. I have a small 23E Thor and do not require a truck. Just a small get around.
I would appreciate your help.
โJul-28-2015 10:58 AM
โJul-28-2015 10:06 AM
GMandJM wrote:
So what brand of tow bar you got there that will let you back up a country mile without bending? Just curious.
โJul-28-2015 08:17 AM
โJul-28-2015 08:05 AM
โJul-27-2015 07:35 AM
Katy Did wrote:
Thank you all very much. Sounds like I can if needed and only a bit. So I'm taking advice to do so only if I really get myself into a situation. Glad to know all this! Thank you all!
โJul-27-2015 06:13 AM
