draw bar question
genekiwi
On the draw bar there are two holes, one for 1000 and one for 1200 lbs.
I have 1000 lb bars and my tongue weight is about 640 pounds.
I have been told that it doesn't matter which hole you use.
Can someone explain how the two holes work?
Thank you
GeneKiwi
2013 Heartland Caliber 26RLSS (Dislike the quality)
2013 Chevy Silverado 1500 (Love the truck)
3 REPLIES 3
mkirsch
Nomad II
Nomad II
In a word: LEVERAGE.
With the shank pinned in the 1200lb position, it is closer to the truck and reduces the amount of leverage the spring bars have on the truck's receiver.
You're right, at 640lbs it does not make any difference which hole you use. The only reason to use the longer hole is if the tailgate hits the jack on the trailer, and being that much farther away will help.
ChooChooMan74
All depends on how far you want your shank to stick out, not going over the rating. I one upped and drilled a hole even closer. Helped when towing with the Liberty. Works now with the Ram, except I can't open the tailgate.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
fla-gypsy
Haven't seen one of those in a while but IIRC the 1200 lb hole puts more of the shank in the receiver which results in the higher capacity
