โAug-03-2019 06:37 AM
โAug-28-2019 06:57 PM
ajriding wrote:I replaced the formed vent with a solid panel. An owner can cover the inside of the vented panel with a solid panel, add in the requisite insulation and have exactly what you desire. When installing insulation, opt for extruded foam board. It is a much superior insulator than fiberglass batt and won't suffer from condensation as much as the spun stuff.
How do you close up the outside fridge vent panel? For me, I will want it 100% weather sealed, then insulated like the walls are insulated.
โAug-26-2019 12:46 PM
Bumpyroad wrote:LarryDel wrote:
We would prefer to plug cooler into 12 volt source permanently because there is not a nearby 120 outlet. Will this cause any problems such as running batteries down or over using 12 volt outlet. Thanks much!
this conflicts with your other statement. will run fine IMHO on shore power. suggesting dumping your $59 cooler for a $800 one seem unhelpful.
bumpy
โAug-07-2019 05:23 PM
โAug-07-2019 08:12 AM
ajriding wrote:
Needs to be 38 or below.
โAug-07-2019 06:51 AM
Lwiddis wrote:
โWill this cause any problems such as running batteries down or over using 12 volt outlet.โ
How can anyone answer without OP giving the Colemanโs amp hour draw? Of course if OP knew the amp hour draw, heโd know the answer.
โAug-05-2019 04:45 PM
โAug-04-2019 02:32 PM
โAug-03-2019 04:12 PM
โAug-03-2019 04:09 PM
โAug-03-2019 03:43 PM
โAug-03-2019 03:04 PM
โAug-03-2019 02:12 PM
โAug-03-2019 12:55 PM
โAug-03-2019 09:30 AM
