โMar-27-2018 10:46 PM
โApr-01-2018 10:55 AM
JaxDad wrote:l like what you said, but I think I will put it on my cycle carrier with some bailing wire, good new wire. I donโt want it falling off.
Itโs all really kind of moot IMHO.
The DOT regโs require anything but a DOT approved cylinder to be securely connected to the vehicles frame, either by permanent connection or approved securing devices. I repeat, TO THE FRAME of the vehicle.
Not to the trailer hitch or other hitch-mounted cargo carriers or motorcycle racks or any such thing.
A couple hundred pounds of propane in a tank is not something you want to fool around with.
โMar-29-2018 05:51 PM
Supercharged wrote:Charlie D. wrote:Charlie your starting to get like someone else we know.
You could put 2 in the front seat. Use existing seat belts to fasten.If your car is old enough to have the vent windows that many had before AC you could run a hose from there to your RV. Use duct tape to seal the vent window to keep bugs and critters out.:)
โMar-29-2018 03:23 PM
โMar-29-2018 11:50 AM
โMar-29-2018 11:00 AM
โMar-29-2018 10:47 AM
fj12ryder wrote:time2roll wrote:He's talking about a 40 gallon, not a 40 lb. tank. Got to be looking at about 300 lbs. or thereabouts. Not something you're going to schlep around.
I would get 2x 30# over a single 40. May want to have some type of carrier for the car too so you can run out for a refill without moving home base.
โMar-29-2018 05:55 AM
Supercharged wrote:dbbls wrote:I plan on leaving it on the back of my RV all season, fill it up there.
I assume you mean 40 pound tank. Have yu tried lifting a 40 pound tank full of propane. Thirty pounders are all i want to horse around.
โMar-28-2018 06:47 PM
^ oh boy. Almost as weird a post as the original one!
Some real cousin eddy sh___going on here!
Actually have no idea what the op is even talking aboot.
You did recognize the OP didn't you? My response is appropriate for the question he asked.:R
โMar-28-2018 05:40 PM
โMar-28-2018 05:36 PM
โMar-28-2018 05:04 PM
dbbls wrote:Here what size it is, 21 inches by 32 inches. What size is that?
โMar-28-2018 04:31 PM
โMar-28-2018 03:21 PM
Supercharged wrote:Put a portable propane cylinder between the MH and toad? :E
I have a 15 gal now and it don't last that long for us. I thinking of putting a second larger tank where I carried my motorcycle. I now pull a small car, so could put the tank there. Good or bad idea.
โMar-28-2018 03:14 PM
