Feeling a lot of heat on outside furnace vent
goodwin297
Hi All,
There is a lot, I mean a lot and very hot heat coming through the vent on the outside of RV. Is this normal?
Thanks,
Trudi
Full-Time RVers since 6/16/2012
Our home:2015 Evergreen Bay Hill 340RK
2014 Ram 2500 Laramie 6.7 Cummins Diesel Crew Cab
Doggies - Molli, Indi and Louie
22 REPLIES 22
beemerphile1
I don't know where you guys got those numbers. Most RV furnaces are 78-80% efficient which means 20% of your LPG is wasting heating the outdoors through the exhaust.
Want to determine the efficiency? Look at the label on the furnace. Divide the output BTU by the input BTU to determine efficiency.
example;
24,000 output BTU
divided by
30,000 input BTU
equals
0.8 which is 80%
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
RoyB
On my OFF-ROAD POPUP this heater vent is just inches away from my normal fabric window flap. Amazing amount of heat going up the outside wall of the POPUP. I have to make sure this flap is tucked up high all the time...
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
SteveAE
pianotuna wrote:
I wish there were a way to use that heat--but I've not found anyone who has come up with a safe solution.
X2
TucsonJim
On cool mornings, I love to have my coffee while the DW is getting her beauty sleep. I like to sit near the exterior vent and enjoy the "wasted" heat.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
past-MIdirector
The furnace heats the heat exchanger and exhaust out just like a house furnace. They are not high efficiency type so they do waste some heat but your duct temperatures are higher than the high efficiency so they do heat the rig up fast!
pianotuna
Nomad III
Nomad III
Hi Trudi,
The furnace approaches 65% efficiency. The other 35% goes "out the chimney".
Regards, Don
goodwin297
Thank you, Harold! I appreciate the quick response.
harold1946
Yes its normal. About 60% of the heat is lost to exhaust.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
