Thanks guys – this is really helpful! Peg is right, we did finally figure out we need to check diameter and they are pretty close. The load capacity is higher on these current low profile aftermarket tires than the stock OEM would be. We bought the truck used last year and it came with aftermarket tires/wheels. Stock OEM for our Lariat should be 18” wheels but it appears there are F150s with 17” OEM as well.
@APT – when we towed a 4000 lb TT, it seemed to work hard uphills but maybe that is to be expected.
@ Skipnchar – we have no idea if the speedometer was adjusted or not, is that a standard adjustment that a tire distributor would do (or is that only done by dealerships)?
@ MFL – thanks for taking time to answer our questions offline – just to share with the group what we calculated on our aftermarket tires:
- The stock 17" tires on a comparable F150 are 255/65R17, which are 30.05 inches. The manual says this can haul 14,000lb.
- The stock 18" tires on my F150 Lariat are 265/60R18, which are 30.52 inches. The manual says this can haul 13,500lb.
From that, I figure that about half an inch of wheel diameter is worth about 500lb of tow capacity. If I use excel to do the math exactly, then I see that:
My current 20" tires are 285/50R20, which are 31.22 inches. This calculates out to 12,752lb tow capacity.
I should also add that our truck has 115K miles and two of the tires had holes patched since I discovered nails after buying it. I recall hearing horrible sound on freeway driving it home so maybe it happened them or they were already there – who knows. Now thinking aloud, am I compromising load capacity with two patched tires???
