Help with scale numbers
oxygen
Weighed at local grain elevator and here are the numbers
truck by itself
steer axle-3240lbs
drive axle-3000
gross weight-6240
tt + tv- WDH(equalizer) bars disconnected
steer axle- 2940
drive axle- 4200
trailer axle - 5360lbs.
gross weight- 12500
tt + tv-WDH engaged
steer axle- 3060
drive axle- 3900
trailer axle- 5540
gross weight- 12500
tv is Rockwood Ultra Lite, ship weight- 5676, hitch weight- 739
gvwr- 6739, this info taken from web site, yellow sticker on side of tv for dry weight is 5840lbs
tv iv 2012 f150 EB, screw, heavy duty, payload is 2440lbs.
please ?check my math
total gross weight mlnus truck gross, engaged = trailer weight = 5540lbs
tv engaged Wdh minus tv unhitched = 720lbs , weight transfered to tv
tt hitched axle weight minus tt unhitched axle weight = 180lbs.
720lbs. + 180lbs. = 9oolb tongue weight
tongue weight is 16% of tt weight
front axle tv unhitched minus hitched front axle = 300lbs.
engaging wdh put back 180lbs to steer axle
is tongue weight added to tt axle weight to get tt weight?
any adjustments needed?
any adjustments i should make to wdh?
2012 F-150 XLT,screw, EcoBoost-3.5 liter, Heavy Duty, payload 2400
2014 Rockwood 2604WS, Equalizer head
36 REPLIES 36
lbrjet
The weight of your trailer is 6,260.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
TomG2
How much front axle weight restoration does Ford recommend in your owner's manual? You are over the 50% that others have mentioned.
Bob_Olallawa
oxygen wrote:
It seems to track well. once in awhile the front of tv seems light to me
thanks
It looks like if you can adjust the hitch, you can put back another 150 LBS on the front axle of the truck.
Welcome to my home, that door you just broke down was there for your protection not mine.
Bob_Olallawa
thanks
It looks like if you can adjust the hitch, you can put back another 100 LBS on the front axle of the truck.
oxygen
thanks
Bob_Olallawa
"is tongue weight added to tt axle weight to get tt weight?"
Yes it is included in the trailer total weight
ChooChooMan74
900 pounds looks right. How does it handle? Do you have any adjustment left? You can try tilting the head back and see if it rides better.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
