โMar-29-2014 01:41 PM
โMar-31-2014 06:32 PM
โMar-31-2014 05:07 PM
Francesca Knowles wrote:Exterior located sewer cleanouts are OK with my State Code, based on UBC so should carry through most States.ACDNate wrote:Francesca Knowles wrote:
You mean a cleanout/access tee, right?
I'll hussle on down to City Hall just as soon as you put up links to any municipal system that imposes any such requirement for such a small upfit to a single-residence's sewer line along with the applicable restrictions as to putting sewage into it.
The point you are missing is that utility systems aren't the most open minded with doing things that a system wasn't designed for. Of course it would work fine, thats not the point.
:h
I've actually participated in a long planning process for a municipal sewage system, and can assure you that they're designed to treat sewage. And since "sewage" is what's in an RV black tank.... what exactly IS your (and Mocoondo's) point?
โMar-31-2014 02:50 PM
โMar-31-2014 02:29 PM
โMar-31-2014 02:11 PM
โMar-31-2014 12:19 PM
โMar-31-2014 12:13 PM
โMar-31-2014 11:57 AM
โMar-31-2014 11:40 AM
โMar-31-2014 11:30 AM
โMar-31-2014 10:33 AM
Mocoondo wrote:Francesca Knowles wrote:
Assuming you have a link to provide for any Municipality that "doesn't allow" sewage to be dumped into a cleanout:
How does that Municipality monitor/enforce such a restriction without a metering system?
Let's rephrase.
If you are on a sewer, go down to city hall and try to pull a permit for installation of an RV dump station at your residence. See what happens next.
โMar-31-2014 10:29 AM
Mocoondo wrote:And what about the 100 gallons you fill at home and dump elsewhere? It all evens out.
As devil's advocate to your above scenario, say you added 100 gallons of water to your tank in a California campground and then brought it home to Texas to dump. You are not paying for the sewage treatment in that case.
โMar-31-2014 09:22 AM
mowermech wrote:
HMMM...
If I am on a municipal water/sewer system, where the water use is metered, and I fill my 100 gallon water tank from my outdoor faucet, then dump 50 to 75 gallons of waste water into the municipal sewer,
how is it that I am not paying for the water I used and the waste water I discharged?
โMar-31-2014 08:22 AM
