โSep-22-2015 03:28 PM
โSep-27-2015 03:36 PM
โSep-25-2015 03:33 PM
โSep-25-2015 02:32 PM
โSep-25-2015 01:54 PM
โSep-24-2015 10:24 AM
โSep-24-2015 10:10 AM
โSep-24-2015 07:21 AM
goducks10 wrote:
Seems like it's a lot cheaper and way easier to switch flow restrictors IMO. Like it was mentioned above you'll use the same amount of water. It will just take less time to fill the coffee pot if that's what you're doing.
โSep-23-2015 03:31 PM
โSep-23-2015 10:04 AM
3oaks wrote:Chris Bryant wrote:
There are a lot of running water uses that are not filling something- like washing your hands. With a limited water supply, using an extra gallon per minute can add up.
Yes, but you don't have to open the water faucet to full flow. We just turn the faucet handle part way to restrict the flow to conserve water usage.
โSep-23-2015 09:43 AM
โSep-23-2015 09:17 AM
โSep-23-2015 08:39 AM
โSep-23-2015 08:31 AM
โSep-23-2015 07:32 AM
Chris Bryant wrote:06Fargo wrote:Dutch_12078 wrote:egarant wrote:
In regards to installing an accumulator tank, I called Shurflo and a tech told me that the pump model 4008 did not require an accumulator tank and that it would be a waste of money.
The tech was wrong... If your 4008 was pulsating, an accumulator tank would stop it. The Revolution (4008) bypass pump is supposed to eliminate cycling/surging, but it doesn't always work as well as they claim, especially at low flow rates.
Roger this ^
x3- there is an adjustment for the bypass pressure- it is not always well adjusted. Proper adjustment, or simply adding an acumulator would be a fix. The tech really dropped the ball on this- that pump should not pulsate.
