โSep-21-2015 04:39 PM
โSep-27-2015 05:29 PM
Ductape wrote:
That's assuming the 6.7 is an upgrade from the 6.8.
โSep-27-2015 07:18 AM
โSep-24-2015 09:31 AM
SRockwood wrote:rockhillmanor wrote:
You can read all the specs what a gas MH is 'rated' for until your eyes cross but when it comes time to head out RV'ing, vacation, etc if your towing a heavy toad the trip will most certainly not be fun for the driver.
I tow a Tracker under 3,000 lbs with a E450. On the straight away you can't even tell she's there. Start going up even the lowest grades and you know it's back there.
Most buy the lightest toad they can to pull behind a "gas" MH.
Unless you like hearing your trans screaming on the steep grades as you try to maintain the speed limit which you most likely will not as it floats out half way up.
A DP MH is the way to go with a heavier toad. Just saying.
The price difference between the DP and a class C is enough that one could replace the transmission 5 or 6 times and stay in a Hilton while repairs are being done and still come out on top. ๐
Some people don't like revs. Others trust that Ford/GM/whoever knew what they were doing when they specified maximum engine RPM.
Not many people put enough miles on these things to see any difference in service life between towing a heavier towed or a lighter one. The curb weight delta between a "light" car (most "light" cars these days are still north of 3000lbs) and a full size SUV is still only 10-13% of the total weight going down the road.
Let it rev and watch your temps with real gauges. If you don't want to do that, then strictly adhere to the manufacturer's guidelines. They're for people who want to just hook things up and drive down the road without looking down.
Besides, I don't know about you, but all the other noise of driving a house down the road makes the engine somewhat pleasant to hear. ๐
โSep-23-2015 06:41 AM
โSep-22-2015 07:34 PM
โSep-22-2015 03:17 PM
โSep-22-2015 12:47 PM
ugh wrote:
A lot of people go over the weight limit. If you do that, I would recommend staying on top of replacing the transmission fluid on time. When I go over the limit, I change the transmission fluid as soon as I get home. Once the transmission overheats, it no longer can do the job effectively and that leads to damage transmission.
โSep-22-2015 07:42 AM
โSep-22-2015 06:10 AM
โSep-21-2015 08:35 PM
โSep-21-2015 06:49 PM
โSep-21-2015 05:57 PM
โSep-21-2015 05:44 PM
โSep-21-2015 05:24 PM
