How to avoid getting blown all over the road
MyersAvionics
Hello All,
Curious on how I can avoid wind blowing the camper and my truck all over the place to the point of it being really annoying to drive and causing me to not even want to use it.
I have RAM 1500 with the 5.7 V8. It doesn't work too hard to pull my 29' toy hauler (7k lbs empty and ~8.5k with stuff loaded) at 65mph down the road. The problem comes in that even with slight side wind gusts I'm blown all over the place and I have to slow down to about 50mph to keep it drivable.
I have a BlueOx hitch with sway controls as well as the trailer friction sway control.
I have LT tires and after getting the weight distribution down pat, I have also installed airbags in the springs to keep the truck level. This helped, but I am still getting blown around the road.
I'm to the point of looking at a larger 2500 diesel RAM, or a full on drivable RV toyhauler, or just an RV that I would put a standard trail behind.
Before I go to these (expensive) extremes. Does anyone on here have any advice on something I could be missing?
Thank you,
62 REPLIES 62
Grit_dog
Navigator
Navigator
^ The dealer didn't air up the tires for what you "might" haul, so that is not part of the equation.
What was the improvement in tires, because you said you had LT tires to begin with?
Since you haven't compared how it drives without wind, hard to say if your issue is all wind, but be that as it may, good luck getting it figured out.
MyersAvionics
Thanks for all the feedback. I think I have a solid plan going forward.
$1,300 later, I have some solid tires on the truck. I'm going to look up to see how much pressure I should be running in them when towing. The dealer put 40psi in and when using a tire pressure calculator it shows I should run 52psi.
Next weekend, I'm doing a short drive for a race. I'm going to load up the camper and then take it to a CAT scale. I'll do 2 passes. One with the TV by itself and then another with the camper to see how the weight is distributed. I'll get it all sorted to ensure weight is properly distributed. Note that I don't have any 'big' toys in the back. Just a couple modern dirtbikes so they weigh a little over 200lbs each. No big 1500lbs SXS's being loaded!
After that trip, if I still feel it is warranted, I'll spring from the ProPride hitch so I have it for a trip to the UP to race later this month. That will be a bit longer 10hr drive so it would be nice to have.
JRscooby
Mike134 wrote:
valhalla360 wrote:
JRscooby wrote:
Your trip to the Cat. Make 1 pass, hooked up like you tow, another with just TV. I have never understood what useful info is gained with loose bars, but the change in weight of TV, and where that weight rides is important info.
BTW, if you tell them it is re-weigh for the 2nd (or more) passes only charge a fraction.
For an extra $2-3 get all the info.
It's technically possible to back calculate with just the 2 measures but beyond most people's understanding of how to calculate.
I don't see how that's possible because you'd have to guess at a variable. For example calculating tongue weight would be impossible from one pass with just the truck and the second pass with weight bars connected which will put weight on the front axle and ADD weight to the trailer axle. You'd have to guess what the tongue weight is.
Well first you must understand the TW when the trailer is setting on the jack is meaningless. The number you need is the TW when hooked up, ready to go down the road.* Once you get that idea between your ears you have 3rd grade arithmetic following a 5th grade word problems. Now this is approaching the extent of my education level, other than what I learned making a living, but I will try to break it down.
The 2 passes will give you 7 numbers. TV steering (S1), TV drive (D1), TV gross (G1), Combination steering (S2), Combination drive (D2) trailer axles (TA) and Combination gross. (G2)
Want to know the TW while in operation? Add (S2) to (D2) then subtract (G1). Trailer weight? Subtract (G1) from (G2) How much of TW is transferred to steering? Compare (S1) to (S2)
*And before you go talking accuracy, understand if you need a WDH, the TW that shows when bars are loose will be more than actual.
blt2ski
Moderator
Moderator
As Barney points out, better hitches make towing nicer....But with this said!
You should be able to drive in windy conditions with out major amounts of uncontrolled fishtail sway! If any at all. If you have this issue, something is wrong with the setup. You need to figure out what is causing the "EFFECT" - fishtail sway, fix the cause.
Yes putting on a Hensley will stop the sway. BUT you trailer still wants to sway! If something breaks, gets loose, you are back to a swaying rig!
I'm going going to resay what I have over the last 20 yrs or so on this forum.
Fix the cause of the sway, then and ONLY then, tow with the "safety bars" attached. Otherwise you have used a band aid to fix what needs a tourniquet!
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
BarneyS
Here is a post that I made quite a few years ago but it fits right in with this topic today.
Today, my wife and I were traveling home from our winter stay in Florida to Michigan. This was the 2nd day of the trip. We started out the morning South of Atlanta GA, and the winds all morning were out of the NW but not too bad. While going through southern Tennessee, we were passed by a smaller GM sport utility truck towing about a 20-21ft dual axle travel trailer. The trailer was swaying back and forth quite a bit, especially as he passed us quite rapidly (we were driving 62mph). I also noticed as he passed a MH in front of us that he started swaying again. I thought to myself,"I wouldn't be surprised to see him in the ditch later".
Sure enough, just as we got over the top of Jellico Mountain right at the Kentucky border, there was a strong gust of wind that tried to move us over but our Hensley kept us going straight. The whole truck and trailer rocked quite severly though. Just a few hundred yards past the summit, there he was. His trailer was on its' side and the truck was in a jacknife position and partly on its' side also. I could not see what type of hitch or even if he had sway control but I am sure it was the wind that got him, given what I had seen before the way his trailer was acting at the speed he was going.
After that incident, the wind kept up blowing VERY hard and causing many vehicles to wander back and forth, including many semi trucks. Our rig remained very stable throughout the day and we only experienced some minor buffeting but nothing to be concerned about.
My wife even commented today on how few RV's we saw on the road. Perhaps the wind was the reason or perhaps everybody was just enjoying the weekend in a campground.
As I sit in a campground now just South of Cincinnati for the night, I am thanking Mr. Hensley today for inventing that hitch, and that I had the means and will to purchase it. Our trailer tows very well with a standard type hitch but I would probably have parked it today if it were not for the Hensley!
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Mike134
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
valhalla360
Nomad III
Nomad III
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Grit_dog
Navigator
Navigator
Lwiddis wrote:
Responders can't say "slow down" too many times. Check the tongue weight.
Exactly how slow should a guy drive? (This is a rhetorical question...)
And it aint tongue weight unless he's got some big toyz in the back.
JRscooby
MyersAvionics wrote:
Thank you for all the input. I added the airbags just as a recommendation from a friend. I sometimes forget to fill them up when towing and don't really notice a difference to be honest.
The plan at the moment is putting better tires on. It is currently at the shop getting the Bridgestone Dueler A/T Revo 3's installed. Then I'm going to load up the trailer and take it to a CAT scale and get it weighed; Once without the weight distribution and once with to see the different load points for the axels. At that point, I'll readjust as needed. I don't carry anything too heavy in the back. Just up to 3 dirt bikes (<700lbs). We then put all luggage and so forth in the front bedroom to help distribute the weight.
After doing the above, I'll take it for a test drive and see how it does.
If it's still white knuckled driving, I will spring for the ProPride hitch. That's a tough 3k bill to swallow for a hitch, but it's cheaper than a 60k+ truck.
Finally, if all else fails we have discussed selling the trailer and getting a toyhauler RV. Talking big bucks there, so I'd like to avoid that!
MyersAvionics
valhalla360
Nomad III
Nomad III
memtb wrote:
IMO .....the felt effects of a cross-wind are directly related to the square footage of the rv side wall area and the weight of the rv.
This brings up an important distinction.
In a good cross wind, you will get pushed side to side no matter what but it will be the whole rig. When a semi blows by you doing 80, you will feel the bow wave and then it immediately settles back into line.
It's sway where the trailer is just wobbling back and forth and doesn't want to go back in line that is an indicator of a problem.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
ktmrfs
are you sure the WD hitch is properly set up and transferring ENOUGH weight back to the front axle??
Several friends of mine complained of issues like yours and when I examined their setup the hitch was NOT transferring enough weight back to the front. so... the front end was lifted, camber was affected and the front end wandered to easily. Once the hitch was adjusted to put enough weight back on the front end the difference in handling was dramatic.
so, check and see if the front wheelwell height is the same or only slightly higher loaded than unloaded. You do NOT want it lower loaded,
2011 Keystone Outback 295RE
Grit_dog
Navigator
Navigator
Additionally, this could also be a case of a person's perception of what is "excessive". Everyone's experience and expectations are different. True story, Ram coil sprung trucks are squishy, but we're talking side loads, not longitudinal loads. Coils don't really have anything to do with side load on the hitch (hitch is low and centered), unless your track bar bushings are shot.
While that's alot of trailer for the type of suspension, I'd suggest the OP work to maybe try towing in the wind with a heavier truck. Friend or relative got a big boy truck to try out?
This will give the OP a frame of refence for the improvement to be expected.
Bottom line, some people freak out when a side wind hits. But it happens and trailers move. If you're freaking out when the semis are getting blown around, it's likely a stout wind and par for the course.
If you're concerned when the semis are tracking straight then it's the truck or your perception/expectation.
Grit_dog
Navigator
Navigator
Devo the dog wrote:
atreis wrote:
How heavy is the tongue? Tongue weight should be 11-15% of total trailer weight. If you don't have enough tongue weight when fully loaded, it'll be all over the road, and potentially very unsafe.
Being a toy hauler, too light of a tongue is also the most likely scenario.
This is what I'd guess is the problem. Tongue weight is too light.
One of my trailers is a 34 ft bumper pull and I always check it with a tongue weight scale.
Unless the OP's 1500lbs of "stuff" is ALL payload at or near the rear of the garage section of the camper, this is almost certainly not a light tongue weight scenario.
And at that, front storage compartment and fresh water are both forward or well forward of the axles. And "toys" will only reduce tongue weight maybe at a 50% rate max compared to their actual addition to the payload, just due to typical toyhauler axle placement.
Grit_dog
Navigator
Navigator
1320Fastback wrote:
I heard a rumor opening a window on each side of the trailer even just a little bit helps reduce the sway from cross winds or big rigs bow wave.
This is an interesting theory that kinda makes sense. I'm going to try to remember to try it.
