โJun-17-2015 12:32 AM
โJun-19-2015 05:15 PM
โJun-19-2015 10:30 AM
nomad297 wrote:tragusa3 wrote:
Will a stud finder work on an aluminum framed trailer?
Yes.
Twenty bucks at Lowe's.
Bruce
โJun-17-2015 08:40 AM
myredracer wrote:
They often install a sheet metal backer plate behind the wall finish. Use a magnet to try and find the outline of it. If aluminum studs, there may not be one where you need it, or even none at all. Our trailer has a backer plate in the bedroom and when I drilled a pilot hole, the plate wasn't where the sticker said it should be - grrrr. (At least you can't see the tiny hole in the wall unless you look real close.)
Apparently they throw the plates in wherever they feel like, and then a different guy comes along afterwards and places the sticker on the wall in the vicinity of where the plate should be. It's a good plan not to rely on the sticker for the backer location.
โJun-17-2015 08:37 AM
Halmfamily wrote:
If it's an outside wall look at your exterior wall first thing in the morning. The condensation will show where your studs are. Looking at mine they appear to be 24" OC. Measure over from a window or door opening as there will be stud on each side.
Interior walls just knock along the wall until you hear one.
โJun-17-2015 08:35 AM
โJun-17-2015 04:43 AM
โJun-17-2015 04:36 AM
โJun-17-2015 04:07 AM
โJun-17-2015 03:13 AM
