โJun-24-2014 12:31 PM
โJun-25-2014 09:30 PM
โJun-25-2014 02:15 PM
โJun-25-2014 07:05 AM
โJun-25-2014 07:02 AM
โJun-25-2014 05:12 AM
hedge wrote:
Interesting, I only have the basic sync system without nav on my trucks since 2009 and never had a problem charging iphones (3G, 4S, 5). I can see how it may not charge an ipad very fast as they pull 2 amps if they can get it.
I just recently added a bunch of 12v plugs and usb plugs inside my truck camper. It doesn't directly help you but may be another option.
USB and 12V plugs
โJun-25-2014 03:23 AM
โJun-24-2014 06:18 PM
Fastfwd75 wrote:hedge wrote:
You have a USB plug in the dash, use that to power the ipad.
In the back of the console you have a built in 150w inverter, use that for the laptop.
2 problems with that.
- The Sync USB plug is standard USB and limited to 0.5-0.9 amp. The apple stuff does some electronic handshaking and will draw almost 2 amp. My phone actually discharges when using navigation while plugged into the sync USB.
- I have the 6 seats so no 150w built-in inverter. I added an inverter anyway so 120v in the truck is taken care of. I want things to work from the trailer too.
โJun-24-2014 05:16 PM
โJun-24-2014 04:59 PM
โJun-24-2014 04:27 PM
Artum Snowbird wrote:
You would want to connect an inverter directly to your battery. Most TV plugs in RV's are not designed to produce much more than 80 watts and the wiring is extremely light to the plug. Far better to use a piece of No. 8 wire and hook up to an inverter of several hundred watts.
โJun-24-2014 04:24 PM
โJun-24-2014 03:24 PM
โJun-24-2014 02:50 PM
โJun-24-2014 02:44 PM
