โDec-06-2013 07:42 AM
โDec-23-2013 12:08 PM
โDec-20-2013 10:38 AM
โDec-20-2013 06:02 AM
06Fargo wrote:OhhWell wrote:06Fargo wrote:RCMAN46 wrote:
Better yet tie a 15,000 lb trailer behind both and head them up a 12% grade and see what would happen.
Horsepower is king and will always win as long as traction is not lost.
So a 450 hp gas pickup truck will haul 15,000lbs to the top of the grade same no sweat as a 450hp ISX15 truck engine at 1650lb-ft?
No, but given a long enough hill and similar drivetrains with CVT, they would both eventually hit the same top speed. The Gasser would just take a bit longer to get to it.
I don't know about the sweat part.....
Math is not my greatest skill so bear with me:
So if the grade is long enough, and all other factors and weights and CVT's are identical (either engine can run where it makes it's 450hp) a 450hp / 430lbs-ft engine hauls up a 12% grade at the same speed as a 450hp / 1650lb-ft engine?
:h
โDec-20-2013 04:10 AM
โDec-20-2013 04:03 AM
โDec-20-2013 03:44 AM
โDec-20-2013 01:19 AM
โDec-20-2013 01:15 AM
danojeno wrote:"Yep pretty much sums it up, this is why gassers rev on hills and diesels don't."
โDec-19-2013 09:47 PM
christopherglenn wrote:
And I was under the impression HP was torque @ rpm.
โDec-19-2013 03:14 PM
โDec-16-2013 07:35 PM
campigloo wrote:Rockrash wrote:
HP= how fast you hit a brick wall.
Torque=. How far you push the brick wall.
Love it!!
โDec-16-2013 04:10 PM
OhhWell wrote:Passin Thru wrote:
My GE 6000 HP locomotive with 200,000 ftlb of tractive force will outpull your little JD tractor. It only weighs 432000 lb.
You own a train?
โDec-16-2013 12:51 PM
โDec-16-2013 03:53 AM
