โMar-08-2020 07:20 PM
โMar-10-2020 08:12 PM
โMar-10-2020 01:59 PM
โMar-10-2020 10:01 AM
cummins2014 wrote:Bosh. Although I've used the EZ Lube grease zerk in the past, I've come to believe that it isn't really necessary. Once the grease is in the wheel bearings and behind the seals, it isn't going anywhere, so there's no real need to add new grease. In all the years I've been driving, over 56 years, I've never disassembled a wheel bearing, on any vehicle, simply to regrease it. I might use the EZ Lube zerk after a few years to put in some fresh grease, just depends on how I feel about it at the time.azdryheat wrote:
Find a friend or someone reputable to repack your bearings. A quality job with quality grease will last you many years. I also have the EZ lube bearing but don't want to chance blowing grease past the inner seal and I find no reason to fill the entire hub with grease. repack and be done with it.
I agree nothing replaces hand packing bearings , EZ lube is asking for problems .
โMar-10-2020 08:50 AM
โMar-09-2020 06:29 PM
โMar-09-2020 05:33 PM
โMar-09-2020 05:19 PM
โMar-09-2020 03:26 PM
Lynnmor wrote:
When you say it didnโt take grease, I think you may have been using the grease fitting, that is a good way to blow the seal. I never use that useless thing.
โMar-09-2020 10:26 AM
โMar-09-2020 09:47 AM
โMar-09-2020 08:56 AM
