inside water leak from rv roof a/c unit
jprt1249
Everytime that it rains, I get a water leak around the a/c unit along the ceiling inside and around a few ceiling vents. I have a Duo Thermo Dometic rooftop A/C. Not sure if these units have a gasket that might be old. Please help.
11 REPLIES 11
willi4nd
I know it leaks when it rains but could it possibly be a blocked condensate drain? Worth a check
New to the RV world and loving every minute of it.
2015 Nissan Frontier 4x4 6 cyl
2015 Trail Runner SLE 22
marji
water leak
1492
Moderator
Moderator
Moved from Forum Technical Support
NashTT
Make sure the bolts have not been over tightened. Had one that wore a hole in the roof under the unit where you couldn't see it until the AC was pulled off. The slight movement going down the road combined with the AC touching the roof caused the hole. Chased this leak for several weeks until I pulled the AC and there it was. Patched the hole, put on a new gasket and used it for nine more years w/o any more problems.
"The opposite of Progress is Congress"
2013 Nash 23F
2008 Doge Big Horn Hemi Quad Cab 3.92
Reese 1000 bars-Prodigy Brake control
Jill, the crazy Rat Terrier always along
Old-Biscuit
Roof A/C Unit uses a 1" thick roof gasket.
4 bolts hold down A/C Unit to roof
Gasket gets compressed by half to properly seal.
Bolts can loosen over time. They should be 'snug' (20 INCH pounds).
Over tightening them can warp gasket/roof causing leaks.
downtheroad
Check this out...it's from one of the Forum members that really know his stuff.
Also make sure the drain holes in the pan are not plugged...
Roof AC Leaks....LINK
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
jprt1249
Thanks again. I will keep that in mind.
azrving
When you pull it off you may find that the sandwich design of the ceiling has collapsed or crushed together. The gasket is pretty firm rubber. I repaired a roof ac opening area and glued in small blocks of wood to give the area more support.
If this has been going on a while it may have messed up the plywood around there. If the membrane around that area is bubbled up or wavy it's damage to the plywood.
jprt1249
Thank you for your reply. I will work on replacing the gasket if it has one. The water leak pattern around the a/c vents appears to follow the slight tilt on the RV as it is parked. Thanks again.
Dick_B
X2 on tightening the four bolts but this may not explain the leaking around the vents unless the water ran along the ceiling to the nearest vents.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
wildtoad
Most rooftop ac units have a gasket that can wear out overtime. There also should be four bolts that are visible if you take the inside cover off. Try tightening them, but not too much.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
