โFeb-09-2014 09:41 PM
โFeb-12-2014 05:55 AM
โFeb-12-2014 05:54 AM
rexlion wrote:People add/change their signatures mid thread...
The OP's sig shows that they have a 5th wheel. So I take it they have traded for a longer 5th wheel. Therefore the discussion about TT towing is not applicable.
โFeb-11-2014 05:11 AM
โFeb-11-2014 02:45 AM
JBarca wrote:tsetsaf wrote:
New trailer is a triple axle.
New trailer is 7' longer.
Truck is rated to handle the weight; should there be any concern about the length?
Hi,
What is the new trailer length? and do you know the TW% of the GVW of the trailer?
Triple axle generally implies higher weights, this many times comes with much longer length.
It may be better if we know what trailer you where up sizing to.
John
โFeb-10-2014 08:51 PM
โFeb-10-2014 08:29 PM
โFeb-10-2014 08:22 PM
โFeb-10-2014 04:12 PM
โFeb-10-2014 04:07 PM
โFeb-10-2014 01:52 PM
Ron Gratz wrote:blt2ski wrote:
MIN WB for ANY trailer is 110" ie up to 20'
Then you need 3" of WB per 1 additional foot of trailer length
First -- the "rule of thumb" does not say a TV with WB less than 110" cannot tow any trailer. It just uses 110" as an arbitrary starting number for the "relationship".
Second -- the "rule of thumb", which frequently is attributed to the RV Consumer Group, says 20' TT for 110" WB, and then add 1' of TT length for each additional 4" of WD -- not 1' for each 3".
IOW, all those people with 130" WB Suburbans should not be towing trailers longer than 25' and a 157" WB pickup should not be towing more than 29' (if you want to believe the "rule").
Third -- AFAIK, nobody has ever produced any data or analysis to substantiate the "rule".
Ron
โFeb-10-2014 01:25 PM
โFeb-10-2014 12:47 PM
โFeb-10-2014 04:40 AM
โFeb-10-2014 02:00 AM
