โMar-09-2014 05:31 PM
โMar-15-2014 10:13 PM
โMar-15-2014 08:06 PM
jody h wrote:
Has anyone used theses tires? Had a blow out today and have another tire ready to go. So its time for new tires.
http://www.realdealtires.com/tires/view/85851
โMar-15-2014 05:18 PM
โMar-10-2014 01:25 PM
โMar-10-2014 10:50 AM
โMar-10-2014 08:14 AM
โMar-09-2014 11:12 PM
smkettner wrote:
I put Ds on mine and run at 60/65 psi. Denman's lasted three years and I hope to get five+ out of the MAXXIS.
If you really want a tough tire get an LT215/75R15 such as GY Wrangler Silent Armor.
http://www.goodyearrvtires.com/tire-selector.aspx#dialog
โMar-09-2014 08:42 PM
โMar-09-2014 08:30 PM
ScottG wrote:
The Maxxis are well worth the small difference in price and it's the only 15" ST tire that many of us will even use.
โMar-09-2014 07:40 PM
โMar-09-2014 06:30 PM
โMar-09-2014 06:27 PM
mrekim wrote:
You're probably going to get opinions all over the map.....
I have the 16" version on a utility trailer used to haul a car. They've worked well for me and seem much better than the tires the trailer came with (3 out of 5 tires failed within a year). The Maxxis have been working for about 3 years now.
There's a heavier duty version in the same size too. I would suggest the heaviest weight rating you can afford and that your rims will take (max PSI rating on the rims). I would even consider getting the tires with the higher ply rating and running them at a lower PSI if my rims didn't support the higher air pressure.
โMar-09-2014 05:54 PM
โMar-09-2014 05:51 PM
