โNov-01-2015 02:47 PM
โNov-03-2015 08:42 AM
wnjj wrote:
Is it this one? Like someone mentioned, could you move the entertainment center wall?
โNov-03-2015 07:48 AM
โNov-03-2015 07:32 AM
โNov-03-2015 06:55 AM
โNov-03-2015 02:30 AM
โNov-02-2015 06:26 PM
myredracer wrote:
Make and model? If manufacturer's website doesn't have adequate pics, maybe post some?
Manufacturers just want it to *look* nice in photos and on display. It's not until you buy one that you find out things like this. We ordered our TT sans factory mattress and installed a better one ourselves.
Our headboard has always been too low and doesn't allow the mattress to get pushed up against the wall. No longer an issue however as the headboard just fell completely off because it was only held on by a few tiny staples. Now I get to reinstall it. :M On the bright side, it will be where it should have been. '
I sleep way better in our TT. One thing you must do is crack a window or two and open a roof vent. We have a FanTastic fan in the bedroom and run it on low and it works great. No airflow means CO2 and stale air buildup causing headaches, etc.
โNov-02-2015 09:21 AM
โNov-02-2015 05:54 AM
Stars101 wrote:
DH and I shopped for 7 years before we finally bought a brand new trailer. Thought we had done due diligence after owning 2 used ones, and camping for 7 years...
Tried out corner queen bed with overhead bunk for the kiddo. It was fine for the 5 min. we spent in it at the RV dealer, but OMG, how horrible it turned out to be once we used it for extended camping. Too cramped and the overhead bunk cut down on the air flow so bad we needed a battery fan to keep the air moving. We HATED it. And we had thought about it before we bought and thought it would be fine.
Even though we were used to smaller beds, and having one of us sandwiched against a wall (and needing to roll over the other to get up LOL) we underestimated the effect of that d*mn overhead bunk. And once we added enough foam toppers it too became even "closer" to our faces.
Sorry for the long post. My point being sometimes you think that you covered all your bases when buying or trading up, and then life tells you differently.... and you end up spending more time and money to get something that suits you better. Sorry it's not working out for you and good luck with a solution - and the 2 bed option might be just what's needed in your situation.
Our best camper was a vintage Shasta that had twin beds! LOL
โNov-02-2015 05:53 AM
Hondavalk wrote:
Would it help at all if you reversed the head of the bed to the foot. At lest you wouldn't have the overhead cabinet in your face.
โNov-02-2015 05:48 AM
โNov-02-2015 05:01 AM
Tacswa3 wrote:GordonThree wrote:
Bed was the number one priority while shopping for my TT. Queen size, so called walk around. I'm almost 7 ft tall and more linemen size than kicker. I know this doesn't help your situation.
If I may ask how did you wind up with such a terrible bed while shopping for your trade up?
It may be cheaper to trade up again but you could try talking to some custom cabinetry makers about redoing the interior, around a more sensible bed.
When we upgraded, our main thing was a walk around bed. Our previous was not. While this one is technically not a true walk around we can enter and exit on our own side instead of crawling over each other. We felt it wouldn't be an issue. After using it a few times, this closed up BR is an issue.
Buying campers is like buying a home mattress. You have a limited time to try it out and don't know how its gonna work out in the long run until it gets some use.
โNov-02-2015 03:58 AM
Tacswa3 wrote:
Brand new TT, queen size bed. Added a foam topper and thick goose down like topper and finally the bed is soft enough and thick enough. BUT... I'm cramped. Can't toss and turn because overhead storage and if not careful I'll hit my head. Wardrobe closets on both sides come down half the length of the bed. And entertainment center is right up against the foot of the bed, making it so you can't stretch out.
Add the wife in the bed and the 2 of us feel cramped and we get no sleep. That puts a damper in the trips and driving back home today I was so tired it took all I had not to fall asleep at the wheel.
I'm not sure what the answer is, but this issue may cause me to trade in. Thing is I just traded up 5 months ago.
โNov-02-2015 03:53 AM
โNov-02-2015 03:15 AM
bikendan wrote:Margos. wrote:
The bed is the FIRST thing my husband and I look at when looking at a RV. He is 6'4 and we know we need the room around the bed. Don't even look at anything else until the bed checks out. Second is the bathroom, then the kitchen and where the TV is. Just how we will look at a new RV in a few years. Already looking at floorplans and know there are some out there that will work well for us and lots that won't. Take your time and look over everything!
Good luck.
DITTO!
