My sleep sucks
Tacswa3
Brand new TT, queen size bed. Added a foam topper and thick goose down like topper and finally the bed is soft enough and thick enough. BUT... I'm cramped. Can't toss and turn because overhead storage and if not careful I'll hit my head. Wardrobe closets on both sides come down half the length of the bed. And entertainment center is right up against the foot of the bed, making it so you can't stretch out.
Add the wife in the bed and the 2 of us feel cramped and we get no sleep. That puts a damper in the trips and driving back home today I was so tired it took all I had not to fall asleep at the wheel.
I'm not sure what the answer is, but this issue may cause me to trade in. Thing is I just traded up 5 months ago.
34 REPLIES 34
cdlaine
Tacswa3...
Frequently understated and over-looked. Should be way - up on
the list of must - haves....right under lay-out. My current
(space) and comfort level is better then in my sticks and bricks.
I commiserate with your problem... not sure what approach I'd take.
Good quality new mattresses seem to start around $800...the "in-cave"
experience probably doesnt have a work around. Good luck.
Charles
2003 2500HD, 8.1L,CC,4.10,2WD,Allison
Standard bed
Ride-rite air bags
Prodigy
Husky 16K sliding
2013 Artic Fox 29-5T Silver Fox Ed.
Pin wt.(CAT Scale) 2660#
5th (Cat Scale) 12600#
I'll want the Frim Fram sauce with the Ausen Fey with
Chafafa on the side.... Nat
brirene
Doesn't sound like OP needs a new mattress, just a bigger sleep area. It sounds horrible to me too, because I like to stretch out while sleeping. Any way to do something with that entertainment center? Sounds claustrophobic.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Chuck_thehammer
a replacement mattress.... trailers are expensive...
for me, a super thick foam egg crate pad.. but that's me.
but sizing the bed was the second thing I made sure fit me. but I am 6'3.
if you can get comfortable ... the size may not be a big deal.
Old-Biscuit
First thing we changed when we hit the road FT was the OEM mattress.
Out it went in the factory plastic and in came the Tempur-Pedic Queen
azrving
Sleep is number one for our old bodies. Could you cut the bed platform down. We threw the old mattress in the lake and replaced it with 6 inches of foam and an additional 2 inch egg crate foam to act as a pillow top.
