New Solar Battery Box by Torklift
FrankShore
For those of you that don't want to put a solar panel on your roof, Torklift makes a nice Solar Panel Battery Box. Now not only can you keep your batteries safely locked up, but charged as well. I think the solar panel is made by Zamp Solar, a well known name! Made in the US of A too! I think I'll be buying one of these ASAP! It will fit my 2 Group 34 Batteries just fine.
Power Armor Solar
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
15 REPLIES 15
MarceloWarn
RoyB wrote:
A typical 10WATT SOLAR PANEL manufactured in solar panels factory will develop around 15-17VDC@ 0.5 AMPS of usable DC Current when in high sun. AMAZON sells 10WATT Solar panel for around $39
PROGRESSIVE DYNAMICs says to charge a 12VDC DEEP CYCLE BATTERY that has been run down to 0% CHARGE STATE which is around 10.5VDC will require 14.4VDC @ 17-20AMPS DC current to be able to recharge to its 90% charge state in a quick three hour time frame. Even this will take a good 11-12 hours of charge to get to its 100% charge state.
It looks like to me the small 10WATT SOLAR PANEL is a bit on the small side. If you was lucky enough to even be in the high sun for the rule of thumb of 6 hours high sun available each cloudless day will only produce around 3AHs... A typical 12VDC battery is rated around 100AHs. The GP24 12VDC Batteries that are usually delivered with our trailer is rated at 85AHs.
The 10WATT SOLAR PANEL only possible purpose in this application would be to a trickle charger for the battery in the box. With only a 0.5AMP DC OUTPUT it would be a weak trickle charge at best...
Having looked up the specs and said all of this I think it is a great idea but it would not replace any of my standard battery charging procedures built-in to my trailer..
The smallest parasitic current drain your trailer has will overcome this 0.5DC AMP charge source. The only time this would be useful for trickle charging your battery would be sitting in a storage mode with a battery disconnect switch operated to totally disconnect the battery from the trailer system. This trickle charge would only be used between the regular required standard charging times.
The only experience I have ever had was with a small rechargeable back yard motion light which used a 7-watt solar panel I think it was. It worked for a couple of season as I recall. When the battery finally wouldn't charge up anymore I discarded it...
Just my observations...
Roy Ken
Thanks for sharing out the review..Sounds like a good product to me..I do need portable charging system and will consider it..
rickeoni
People complain about all posts being the same and them flame a poster for showing something new...jeeesh!
2008 F450
2007 Adventurer 85WS
2012 Haulmark "The Garage"
2016 Outdoors RV Glacier Peak 26 RKS
Raften
Ignore them Frank, the solar should be considered just to maintain but not to charge after a big drawdown.
'01 Dodge 3500 CTD, Lance 1121, Air Bags, Rancho 9000, All Wheels Under Power When Needed, A Few Engine Mods For Increased HP
Burning Grease, 800 ft/lbs. of torque from something you throw away.
FrankShore
Thanks westend. I felt like I was being smashed up for bringing something to peoples attention.
Beemerphile1, group 34 is a common size and they will fit inside the battery box. I already measured my group 34's.
Battery Chart BD Batteries
2014 F-250
westend
Frank,
It's a good product. Torklift makes an excellent box. If you find that you need more wattage, another panel can be added.
Thanks for posting so others know about the product.
'03 F-250 4x4 CC
RoyB
A typical 10WATT SOLAR PANEL will develop around 15-17VDC@ 0.5 AMPS of usable DC Current when in high sun. AMAZON sells 10WATT Solar panel for around $39
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
beemerphile1
Power Armor Solar...
Box - okay
Solar panel on box - waste of money
Group 34 batteries - never heard of that size and they won't fit the box anyhow. From your link; "...engineered to hold and protect either Group 24 to Group 31 12 volt batteries or 6 volt T105 or SC2 golf cart batteries..."
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
I have that exact battery box on my TT. It's awesome - a wonderful product.
But the solar? Put a couple 100's on your roof - you will be much happier. The ten will do next to nothing.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
FrankShore
Sorry, I'm not a shill for the company, I just like their idea for a product. Good strong box to lock up your batteries with a solar panel on top. Seems like a good idea, or not.
2014 F-250
Community Alumni
Not applicable
If you came here looking for opinions, I offered mine. Or perhaps you are a shill for the company that makes the box. If not, and you like it, buy it. It's your money.
FrankShore
I suppose that locking up your batteries is also a bad idea?
2014 F-250
Community Alumni
Not applicable
How much juice is that 10 watt panel going to produce when the sun will be blocked most of the time by the TT and the propane bottles?
FrankShore
It can't hurt can it?
2014 F-250
Community Alumni
Not applicable
The 10 watt solar panel is a waste of money.
