New Trailer Tires - And THANKS
SpeakEasy
I'm sitting here waiting while the tire shop is installing my new Goodyear Endurance trailer tires. These are replacing the original factory-installed Westlakes, with date stamps of 2013. When I ordered the tires I requested that they ensure that the tires were manufactured within the last six months. They are dated 4419 - only a couple of months old.
I owe a debt of thanks to the people who share their knowledge on this forum. All of the following are things I've learned by reading these forums:
- tires have date codes
- trailer tires age-out before they wear out
- 6 years is about long enough to keep trailer tires
- Goodyear Endurance tires are considered by many to be premium tires that are worth the price
- you can request your tire shop to ensure that they are getting tires that are dated recently
- original-equipment, Chinese-made tires have a poor track record
A caveat: I don't take everything I read here at face value. In fact, I don't take anything I read here at face value. However, reading these forums exposes me to ideas that I can then research further. That's what I do. After further research, I reject a fair amount of what I read here. However, the stuff that I keep and follow up on is stuff that I wouldn't have known about on my own.
So - Thanks to all who share! It's appreciated.
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
26 REPLIES 26
BenK
Or allowing the tire's PSI to go too low in regards to the load they are carrying, factored by speed
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
CapriRacer
librty02 wrote:
Cummins12V98 wrote:
I donโ€™t do Facebook. I have done several searches and not one non road hazard has been mentioned.
So as a friend tells me please prove with pics and testimony these you mention are NOT roD hazard.
To be honest I canโ€™t believe there have been none my self but I have seen nothing along with CapriRacer.
I have the pics and they are not road hazard issues they were tire failure themselves as the entire tread has separated from the sidewall. I have posts from facebook and instagram. I would post the pics here but not sure how to from my phone. Can I send them here through a message?
When the tread separates from the sidewall, that is a "run flat" - usually caused by a puncture. I've examined thousands of those and 90% of the time I could find the puncture. The other 10% I speculated that the puncture was in the area of the damage caused after all the air was let out - and this was confirmed by Rex Grogan, a noted tire forensics analyst who published a chart showing a study of where punctures occurred in a tire - and 10% were in the junction between the tread and the sidewall.
The failure mode of interest is a belt-leaving-belt-separation, as described in the Tire Conditions Manual published by the Tire Industry Association. Tire Conditions Manual
This failure is far and away the most common non-road-hazard related failure mode. It is characterized by the tread and top belt detaching in whole or in part, leaving the rest of the casing intact and frequently the tire stays inflated.
If anyone has a photo has one of those in a Goodyear Endurance, it would be of great interest. But if someone only has a tread/sidewall separation, that is NOT of interest as that is caused by a road hazard.
To date, I have not seen nor heard of any.
CapriRacer
Visit my web site: www.BarrysTireTech.com
librty02
2011 FORD F-150 FX4 CREW CAB ECO...
2018 Ford F-150 Max Tow Crew 6.5 3.5 Eco...
2013 Keystone Passport 2650BH, EQUAL-I-ZER 1K/10K
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
librty02
CapriRacer wrote:
CaLBaR wrote:
Just for my own curiosity what does your data show on the new Carlisle Radial Trial HD? I had these on the previous trailer for about a year without any issues and have not notice any failures mentioned on the forums so just wondering if these tires are better now too.
Rob
Sorry, but I don't any data.
First, my experience was with a major tire manufacturer and we only tracked RETURNS for THAT manufacturer. I retired 7 years ago, so not only do I not have current data on ANY current tire, I don't have ANY data at all. What I have been doing is looking at reports on this and other forums and the one that stands out is the Goodyear Endurance. It's the only one I know of where I can track when it was introduced AND there have been no reports of failures. I am sure that eventually there will be a failure reported because consumers don't know how to discern the difference between a road hazard related failure and a failure caused by the design. (Please note: My experience says that by far and away, it is the design - that is, the materials used and where they are placed - that results in failures and not defects - things that aren't supposed to be there and things that aren't there that are supposed to be.)
There are failures of the Goodyear Endurance a few actually. Go to all the Facebook RV pages and you will see pics of them there where the treads have separated from the sidewalls completely the entire way around the tire. I have a few of those pics saved to my phone. I have yet to see a failure on a Carlise Radial HD though...but that may be because they both came out around the same time the Carlise just a few months sooner and everyone is jumping on the made in America Endurance.
CapriRacer
Rob
CapriRacer
JIMNLIN
First, structural tire failures in the winter months are almost non-existent. The last month where you might see a few is October. They start up again in May.
So, yes, I made that prediction in October of 2019 after the season was over. Nothing magical. Just the facts.
Much the same when hoopla when Goodyear redesigned the old Marathons in the early '00s. The new and improved Marathon came out with a circle 6 stamped on the tire.
The first couple of years Marathon owners and users crowed how great they were. Granted they were a vast improvement over the old ones.....but after 3-5 years tire complaints started pouring in.
The Endurance looks like a automotive tire now and doesn't have that rounded sidewall/rounded tread profile that IMO from my experience is not the best idea for a load carrying tire on a trailer.
The Endurance physically looks like big improvement....time and miles of actual service rolling down the road will show Goodyear made a better ST class tire.
CaLBaR
CapriRacer wrote:
Cummins12V98 wrote:
Thanks for the reply!
You actually felt the tire was credible last year. I have saved some of your comments from the past for the nay sayers! :B
Rob
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
CapriRacer
CapriRacer
Hannibal
Itโ€™s only a matter of time before someone picks up a nail, runs low and throws a belt or... pulls into a station and drags the hot tires over the curb unknowingly starting a belt separation. The tire victim will post numerous pictures of the fuzzy bead clinging to the rim while swearing to never buy a GY tire again.
Keep them aired up and covered when not in use. Minus road hazard, should get 5-7 years out of them if you donโ€™t wear them out sooner.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
Cummins12V98
CapriRacer
Cummins12V98 wrote:
At least someone here has decided the ENDURANCE is a credible tire now that it has made it to three full years on the market with stellar results. :B
That would be me.
Former tire engineer with a major manufacturer who tracked returns and developed algorithms to predict return rates. My experience said that after 2 years in the market, you could predict the return rate for structural failures - which peaked in the third or fourth year.
Since no one has reported a Goodyear Endurance ST tire failure in 3 years (They entered the market in the fall of 2016), my prediction is that there will not be any design failures until the tires age out. (We don't know when that will be.)
Please note: That even the best designed tire can suffer from road hazards (punctures and impacts) and those types of failures are difficult for the average person to diagnose. Ergo, people will report tire failures and blame it on the make/model tire even if the cause is not tied to the make/model. Been there, done that! That's why we examined every reported failure for root cause.
CapriRacer
deltabravo
trail-explorer wrote:
Hopefully they balanced the tires too.
Ditto on balancing.
Here's a short video I did a few years ago about trailer tire balancing.
Cummins12V98
Just wanted to have some fun.
You were always quick to say 1 or 2 years on the market was not enough time to prove reliable. But since they have made it to 3 years no one seems to be questioning time on the market.
