โJul-05-2015 12:29 PM
โJul-30-2015 03:38 AM
โJul-29-2015 06:37 AM
โJul-29-2015 03:29 AM
โJul-26-2015 12:47 PM
โJul-20-2015 05:52 PM
Camper G wrote:If you are saying you will try to use the WDH to lift the rear of the truck back up to its unhitched height -- I think that is a very bad idea.
---I think this is pretty good and the weight bars should transfer any additional squat from the tongue weight when loaded back to the front axle.
What do you guys think?
โJul-20-2015 01:12 PM
mkirsch wrote:
If you use your WD bars to pull ALL the squat out of the rear of your truck, or even reduce it to 1", you will be putting way too much weight on the front of your truck.
โJul-20-2015 11:27 AM
โJul-17-2015 01:41 PM
โJul-16-2015 03:39 AM
Turtle n Peeps wrote:As far as braking, think about the first thing your trailer tongue does when you peg the brake pedal. It dives forward (ie, down) and hard. Not saying there's a whole lot of difference in any case between the two settings, but if you're already 1 1/2" down, it's going to be much lower in a braking situation. I have mine set about 1/2" high when loaded and I have no issues. I believe it's more important to get the hitch set correctly to transfer the proper weight to the front axles for handling. My .02.
Not true at all. When you hit the brakes the weight (energy)transfers as far forward as possible. That would be all the way to the front bumper of the TV.
If anyone doubts that, just look at slow motion video of anything braking. The nose of the car, trucks and especially motorcycles dives to the ground. Anybody that has ridden a motorcycle will tell you that the back brakes of the motorcycle are almost useless because of this.
If you have a nose high trailer and when you brake hard the TV will nose dive and then try to raise the back of the TV. It will look like an inch worm.
Ever see a truck and trailer "jack knifed"? This is one of the reasons why. The trailer will try and lift the back end of the TV off of the ground and if it's not perfectly straight it will kick the back end of the truck around. With ABS on the TV this is even more pronounced.
If you set the trailer up slightly nose down when you brake hard the nose of the TV will dive, the back will come up slightly and even out the coupling height. Look at this video to see why nose high is a bad idea.
See how the nose dives and the trailer lifts up around 22 seconds. This is what your trailer will do at a nose up or level attitude.
โJul-09-2015 07:17 PM
โJul-09-2015 03:29 AM
โJul-08-2015 05:06 PM
โJul-08-2015 12:03 PM
โJul-08-2015 08:41 AM
