oil film on a/c filter, what could be causing this?
EASY_RIDER
I cleaned my filter on my a/c unit, and it had a oil film on it, have a roof a/c on my Itasca, 2006 motorhome. a/c works fine, any suggestions would be appreciated.
Tom
8 REPLIES 8
Charlie_D_
Don't know how oil from the refrigerant could get on the supply filter. A refrigerant leak of any size will quickly empty your system and quit cooling.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
tpi
What's the history of the unit? Did oil just suddenly appear after cleaning the filter for years with no accumulation?
Used unit first filter cleaning by you? New unit?
I'm also inclined to think cooking grease. Do you fry stuff on the stove? AC is probably pretty close. I've seen very greasy filters on range hoods.
If it is leaking from refrigerant system, it is not long for the world. Slight chance of a bit of leakage from overzealous lubrication of fan motor.
EASY_RIDER
I'm still wondering, doesn't seem like this oily deposit would be from cooking, however if I pull the a/c cover off and run the a/c while I'm on top would I be able to see the problem if I have a leak?
sch911
ksg5000 wrote:
The only thing up top on my AC unit that has oil in it is the fan motor.
And that would be wrong. There is most definitely oil in solution with the refrigerant to lubricate the compressor. Which of course could only be the cause here if the system were leaking refrigerant from the evaporator coil. But since it sounds like this one is cooling ok I'll go with the others on this. It came from within...
OEM Auto Engineer- Embedded Software Team
Ozlander
And it'll help catch the dust. No problem.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
Clay_L
RV ACs don't bring air in from outside, they recirculate the inside air, so as stated above it has to come from cooking I would think.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
ksg5000
Kevin
the_bear_II
From frying bacon while the A/C was Running ?
