Dec-28-2017 07:29 AM
Feb-02-2018 04:41 PM
Passin Thru wrote:
Run down I20 with 19,000 lb GVW and see if you done think you're on a bucking horse. That's why I have Airlift. Has nothing to do with how much wt the truck will carry. A Peterbilt has Airbags on each side of the rear axles, under the cab and airide seats. I could go to 120,000 lb GVW with permits. Timbrens are bumpstops, by the time they work, you've hit bottom and your Bottom.
Jan-31-2018 06:06 PM
Jan-29-2018 08:37 AM
Jan-28-2018 03:01 PM
Jan-03-2018 07:44 PM
Jan-01-2018 08:21 PM
Dave H M wrote:
it looks like the tembrens work just like an air bag only not adjustable.
Jay D.
:h
Jan-01-2018 06:10 PM
Jan-01-2018 12:27 PM
Jan-01-2018 11:17 AM
Jan-01-2018 10:00 AM
Jan-01-2018 05:08 AM
Dec-31-2017 01:53 PM
Grit dog wrote:
To the OP, I cannot imagine the need for airbags on your truck and setup unless there is a specific need, like you're hauling another 2-3000lbs in the bed with the camper in tow.
You haven't replied as to why you think you need them as you're already running this truck and trailer together. What are you trying to accomplish?
Dec-31-2017 11:18 AM
Grit dog wrote:SweetLou wrote:
Just get some Tibrens. They only go into use when truck has weight on it. Research it and you will see that they are better and less expensive. It won't change the ride when empty either
While I like Timbrens and have used them in the past, as they are one of the most economical "solutions", their downside is they are extremely stiff once engaged. Kind of a not for all situations solution like airbags are.
Dec-31-2017 09:36 AM
