MORE INFO
Are you in an older trailer with a Magnetek 6300 Converter (THe 6300 does not know the lyrics so it hums along)
Many things can cause Hum, The above is all but guaranteed to do it. especially if the radio is after market and hooked to the wrong fuse.
Other things are gound faults. bad converters and external interference
The above applies to automotive adn other DC operated radios.
IF feeding a radio's AUX in with a cell phone powered off the RV's battery.
I mentioned GROUND FAULTS. that's a given with that hook up.
Finally we have 120 volt "Table top or Home theater" radios.
Bad power (MSW inverter) or bad power supply (Blown capacitor or bad diode)
