โNov-08-2019 11:10 AM
โNov-09-2019 07:57 PM
Thermoguy wrote:
I purchased the Yakima rack specifically for use on the back of a trailer. We have a 5th wheel and I know the back bounces a large amount. We have put up to 4 bikes on the rack and driven about 1000 miles on one trip with no issues other than the bikes rubbing. Pool Noodles are your friend.
The Yakima rack has a solid joint where normal bike racks fold to allow access to an SUV or Tailgate. The solid joint is why it works well. It does fit in a 2" receiver and has a locking nut so it doesn't bounce in the hitch. I have another rack that bounces in the hitch which would be bad on the back of the RV.
I would suggest upgrading your hitch to a 2" receiver and buying one of the units that are designed for RV's. I also looked at putting a hitch on the front of my truck and buying a rack for that hitch, but the RV hitch works fine and I haven't had any issues, the bikes are on the rack solid. I do tie them together with straps that come with the hitch.
โNov-09-2019 06:12 PM
teejaywhy wrote:
My intention is to avoid any questionable setup, that's why I'm looking for help to find racks that are spec'ed to be used on a TT. My trailer has both shocks and a factory hitch which is approved for bike rack use. (welded to frame not just the bumper).
The bikes are hardtail mountain bikes @28lbs each.Lynnmor wrote:
I see plenty of them here.
Thanks, Lots of "RV" racks there but unfortunately, after you use the filter to specify "Towable Camper" and "1-1/4" receiver", you are left with one choice, not a great one but an option nonetheless:
https://www.etrailer.com/Hitch-Bike-Racks/Reese/63120.htmlIAMICHABOD wrote:
You could use This XC2 Bike Rack It is RV approved. They also offer the XC It will fit the 1/14 receiver.
The XC2 is the one I use and it is very sturdy, to adapt it to the 1 1/4 you could use one of These
Thanks, The XC2 is clearly labeled for RV/Trailer use but the XC lacks that language ๐
I'm hoping to avoid the use of an adapter.jplante4 wrote:
This goes on the tongue.
Thanks. An interesting solution.
It seems the limiting factor is the 1-1/4" receiver and I may need to explore replacing it with a 2".
โNov-09-2019 11:29 AM
Gdetrailer wrote:
No one suggested a StrombergCarlson A frame hitch adapter..
Shoot, the pix doesn't want to be linked..
See HEREFor pix and details.
Mounts to the A frame and places a 2" hitch over top of your propane tanks.
Found PDF of assembly instructions..
HERE
Amazon link which has a pix showing the adapter..
HERE
โNov-09-2019 11:06 AM
โNov-09-2019 08:55 AM
โNov-09-2019 08:14 AM
โNov-09-2019 07:01 AM
โNov-09-2019 06:26 AM
โNov-09-2019 05:10 AM
โNov-09-2019 05:00 AM
โNov-08-2019 05:55 PM
โNov-08-2019 05:28 PM
โNov-08-2019 03:53 PM
BobsYourUncle wrote:
Have you ever followed behind a TT or 5ver going down the highway with a loaded bike rack?
I have quite a few times. It's rather scary how much it flings forward and back. And you cannot see it from the drivers seat.
I have one for the back of the TT. I'd like to use it but wouldn't consider it without a provision for lateral support to prevent it from flexing to and fro.
Mine is a 2" reciever.
โNov-08-2019 02:07 PM
