โFeb-23-2021 03:30 PM
โFeb-28-2021 09:53 AM
JimK-NY wrote:
If we need to "exercise" a generator to make sure it is still working, what other RV appliances should we exercise? Do we need to operate the stove, refrigerator, microwave, furnace, water heater and/or AC monthly?
โFeb-28-2021 09:27 AM
โFeb-28-2021 06:46 AM
โFeb-28-2021 04:18 AM
โFeb-27-2021 07:30 PM
โFeb-25-2021 04:41 AM
โFeb-24-2021 05:18 PM
dieseltruckdriver wrote:. Wheres the harm? whats the consequence? When mfgr. builds in monthly auto start to exercise for a home propane unit, doesnt that have a n alert to genny users that if you need it on demand, you can depend on it.Grit dog wrote:way2roll wrote:
I'd rather exercise my genny monthly and know it's going to work than find out I have a problem when I really need it. All this doom and gloom about problems it causes by those of us that exercise them monthly is gibberish. It doesn't take a ton of common sense to know that running any mechanical engine frequently is far better than not running it for long periods of time and there is far more evidence behind that than the few who claim running it too frequently causes more problems than it solves. Luckily there are very few people who fall into this category who offer such advice. That is not to say that a genny can't be stored for long periods if certain things are done, like draining it etc. But I'd much rather have a genny that's periodically exercised than one that sits dormant. That's usually the advice that engineers will offer and they don't all have a hidden agenda.
Truth.
Agreed.
โFeb-24-2021 03:58 PM
Truth.
โFeb-24-2021 03:13 PM
enblethen wrote:
I disconnect from shore power while test running genset. You must test run under load.
โFeb-24-2021 11:44 AM
โFeb-24-2021 10:39 AM
โFeb-24-2021 10:28 AM
โFeb-24-2021 09:25 AM
DrewE wrote:valhalla360 wrote:
Obviously, shore power needs to be disconnected unless the generator has a means of syncing with the shore power (small generators we are discussing won't)
Any RV with a built-in generator will have a transfer switching arrangement of some sort which will disconnect the shore power when the generator is supplying power, and vice-versa, so they are not interconnected. Usually it's an automatic transfer switch, but sometimes it's simply having a power outlet connected to the generator that the shore power cord is plugged into.
It is not necessary to disconnect shore power when using the generator, though some do out of an abundance--perhaps overabundance--of caution. It is wise to avoid having the transfer switch operate under any (significant) load, so turning off air conditioning, electric heat, etc. before starting or stopping the generator is highly recommended.
โFeb-24-2021 06:24 AM
valhalla360 wrote:
As long as you put them to bed properly, no reason to be concerned letting it sit for months.
In fact starting once a month is likely doing damage. That's long enough for the oil to drain off all the internal surfaces. Until oil gets pumped back up to the surfaces, you are getting accelerated wear. I would prefer to keep that to a minimum.
