RV AC Longevity
Endricken
I just replaced my Fourth AC on my 2005 Fiver.
Most recent two ACs lasted only 5 and 6 years. Both were installed at the same time.
The Coleman Mach Low Profile 13.5K Bedroom AC that wasn't used that often lasted only 5 years.
The Dometic Brisk Air 15K Ducted/Main AC lasted 6 years.
We do use / live in our RV about 9 months per year (in the Summer or South TX for the Winter which means AC is used a LOT) so for most RVers won't have to replace so often, but I wonder how this might compare to Fulltimers...
Also replaced the OEM Suburban Furnace last Fall as the Blower got noisy. New Furnace is much quieter.
Glad I can fix most systems on the RV myself...
Retired USAF
Silver 05 Dodge RAM LB CTD Dually 4Speed Auto SWD 3.73, Westin Sportsman Grill & Taillight Guards,Husky Mudguards, Retractable Ball Hitch, Onboard Air & Horns, MaxBrake - towing 2005 Keystone Montana Big Sky 3670 with Star Performance adapter
12 REPLIES 12
solismaris
15 years so far; no problems. And I don't hesitate to run it even when the voltage is as 105 volts or lower which is quite common in many campgrounds, and is supposedly bad for ACs.
That being said I use AC rarely; probably 2 or 3 days a year.
David Kojen
mike_brez
Just replaced my 21 year old Dometic with new ones. We shall see.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Veebyes
Replaced a 10 year old Coleman this year. Not much use really but has experienced low voltage a number of times. First the fan motor seized. Replaced that & gave everything a good cleaning. Two weeks later the compressor died. Bought new unit & salvaged slightly used fan motor as spare for new unit.
2007 Alpenlite 34RLR
Endricken
Followup: I use a 50amp Surgeguard all the time.
It was running when it failed, just "groaning" to a stop so I figured it was "shot" and not worth trying to figure out what was wrong being 6 years old (after losing a lightly used Coleman AC after only 5 years).
I will admit to not maintaining the failed Brisk Air recently as well as I should since the Shroud screws stripped from earlier cleanings with AC coil cleaner and inspection/cleaning showed little dirt. However, dumping the Brisk Air off the Roof "removed" the shroud and the Condenser and Squirrel Cage Fan were pretty dusty dirty. On this new one I will be sure to replace any stripped Shroud screws with better ones as needed so I can stay on top of cleaning.
Retired USAF
CavemanCharlie
You may have a low voltage problem. My 1993 TT still has the original AC.
pianotuna
Nomad III
Nomad III
Hi,
Was it a motor failure? If so, I'd encourage you to get an autoformer.
Regards, Don
mdcamping
I've replaced OEM coils that have lasted almost 40 yrs, the replacements lasted 10 yrs. compressors, motors, controls, bearings and even v-belts just don't last as long... this is a overall trend I have had to deal with.
Mike
2022 F-150 3.5 EcoBoost 4X4 Supercrew GCWR 19,500 157WB
Payload 2476 Maxtow 13,800 3.73 Equalizer 4 Pt Sway Hitch
2017 Jayco Jay Flight 24RBS
Old TV, 07 Toyota Tacoma, Double Cab, Factory Tow Pkg, retired towing at 229K. (Son now owns truck)
jplante4
Highly dependent on voltage. My 24 year old Penguins are still going, knock wood. I put in a Progressive surge protector/EMS and keep a good eye on the volts and amp draw.
However, you are correct The new ones don't seem to last as long. I bet we sold 30 AC units this summer and half of them went to 2-5 year old campers.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
valhalla360
Nomad III
Nomad III
Keep an eye on park voltage.
Heavy usage (within reason) is actually better than just sitting for months at a time.
But if you are running at low voltage, it can burn up pretty quick.
15-20yr is pretty normal.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
2oldman
My 17 yo Brisk air is fine. Replaced squealing furnace motor at 16 years. Not a diy.
T18skyguy
It seems nothing lasts as long as it use to. I visit all the rv forums, and AC's failing early is a common thread. Since we can't make it ourselves, we have to keep buying poor quality.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. Between rigs right now.. Wife and daughter. Four cats which we must obey.
Flute_Man
I am a full-timer in my motorhome and My two air-conditioners have lasted 15 years and still going strong.
Jerry Parr
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
