second try - Harbor Freight axle over conversion
motormike73
sorry the pics were way too big, let me try again:
Anyone ever do this and is it safe? Trying to lower my trailer for easier loading/unloading. Here is my "before":
when relocating the axle though I had some issues with the center bolt and the axle not laying flush since its a square/channel axle and not round ie no perch.
i thought just flipping it (as pictured) so the centering hole could now go on the bolt on top as it did on the bottom side when mounted axle under. however i didnt know if having the square channel oriented this way would be an issue. its a straight axle, not cambered fwiw.
thoughts?
11 REPLIES 11
oilslick
motormike73 wrote:
tires are rated at 65mph
as for welding a perch, i assume its not TOO tough of a task to measure/center holes on the perch (where the spring center bolts would sit into)? that was my concern with how difficult it would be to get it centered...
I think it's a very simple job that you could easily do yourself if you can weld, if not then I'm sure most trailer shops could do it for you. The axle tube looks to be 2 inch so a couple pieces of 2 inch x1/4 flat stock with a hole drilled in each piece carefully measured in from the outside end and centered, then any welder could stick it on.
MitchF150
My little utility trailer (Lil' Tex) has the axle mounted like you want to do yours and it came that way. Mine is a round axle with the 5 lug hub, and the U bolts are what takes the weight! I'm running 12" tires too and I've loaded it with 2 yards of bark mulch on many occasions, 1 cord of wood, and lots of other stuff and it's now over 15 years old... ๐Ÿ™‚ (I did get a new set of tires for it several years ago..).
Mitch
motormike73
oilslick
"Flipping" the axle is a common term but that's not how it's done. It refers to moving the springs from one side of the axle to the other (top to bottom or bottom to top)and usually the axle tube has a built in camber. If as you say yours is just straight then the only thing I can see being a problem is that the axle tube will fill with dirt and moisture causing it to rot through very quickly. I would just have a couple of plate/perch welded onto the bottom of the axle and keep the axle upright but hang the springs under.
darsben
But what is the maximum speed rating on those itty bitty tires.
Traveling with my best friend my wife!
motormike73
tires are 990# each....trailer is 1000#. i took the set up to a truck stop and the bike weighed 600#, trailer itself 275#.
Executive45
motormike73 wrote:
i went to 12 inch tires as well, and so have already raised the fenders substantially, so that too should be fine.
Best check the SPEED and WEIGHT ratings on those tiny tires....especially if you're loading a heavy bike....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
motormike73
motormike73
i lengthened the tongue and its only lowering by a couple of inches, i dont think the end bottoming will be of concern. i am more worried about the axle being upside down, so to speak and if this will put undo stress on the u bolts.
i know a couple inches may not be a big deal, but its to carry a very long bike and so so the ramp i need currently is ridiculously long, so trying to do whatever i can to make loading/unloading easier.
We_Cant_Wait
lowering the trl that much might also cause issues with the tire rubbing up in the wheel well every time you hit a bump when the suspension is compressed.
Dannyabear1
The rear of the trailer will now drag on every bump you cross; better to just get ramps
