โApr-13-2014 07:38 PM
โApr-15-2014 12:29 AM
dbates wrote:
Progressive Industries EMS by itself will protect your RV from improperly wired receptacle producing 220 volts, but a multi-meter can be used to verify that the PI EMS is accurate with its diagnosis. I had a campground owner claim that the PI EMSes were often wrong but my multi-meter verified it was correct.
Dave
โApr-14-2014 05:06 PM
โApr-14-2014 01:31 PM
LarryJM wrote:D & M wrote:
As should go to a big box tool store and get yourself an inexpensive multi meter and, if you don't know how, get someone to show you how to use it. It's really easy. I always check the pedestal before I plug in.
This link will explain more about RV electricity
That won't help with the OPs issue since he already knows he has high voltage where he is and can monitor the same at any where else he plugs into.
Larry
โApr-14-2014 10:12 AM
โApr-14-2014 07:47 AM
Why get a multimeter for a one time check when he already has a surge protector performing continuous checks? Just because power is acceptable before you plug in doesn't mean it will stay that way.
Well plug into a 220 improperly wired receptacle and you will wish you had checked. True it does not mean it will stay that way either but you are protecting your rig first of all. Second you can tell what is hapoening on a pole. A fellow camper came over and said only one of his ac units was running. Looked at his system he only had power on one leg. Multimeter showed other leg was 90 volts so his system was protecting the coach but we moved him to another pole and all was fine.
โApr-14-2014 07:35 AM
โApr-14-2014 05:02 AM
โApr-14-2014 04:59 AM
โApr-14-2014 04:19 AM
โApr-14-2014 04:08 AM
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
โApr-14-2014 03:33 AM
โApr-14-2014 03:30 AM
โApr-14-2014 02:59 AM
โApr-13-2014 10:39 PM
