โJan-11-2021 04:49 AM
โApr-15-2021 11:09 AM
โApr-15-2021 07:46 AM
Grit dog wrote:mkirsch wrote:
I've never been able to get the ether to do anything but light the tire on fire and burn off my knuckle hairs. Use a little. Tire fire. Use a little more. Bigger tire fire. Use even more. Even bigger tire fire. Just could not get the "whoomph!" that everyone else seems to be able to get.
You missed a critical step. Did you say "hold my beer" first?
โApr-13-2021 09:42 AM
โApr-13-2021 06:04 AM
Jarlaxle wrote:JRscooby wrote:
Can of starting fluid works better than strap, but likely to send old women screaming and waving hands.
It should probably be a felony, punished with 500 strokes of a barbed wire scourge. Some idiot's ether stunt permanently injured and almost killed my old boss.
โApr-11-2021 05:45 PM
JRscooby wrote:
Part of my point made.
Any time you are around compressed gas, even air there is a chance to get hurt. For years I carried tire irons and patch kit. The tank needed for using large blast of air to get the bead to seal well enough to seat takes up too much room. Woof the bead to seal, inflate to seat, then let the air and unburned ether escape. Inflate to pressure.
Is there a risk? Some. But also a risk when use that tank to blast air in. But the risk to others is much less when the hole is properly patched compared to plugged. I never got hurt, I but also never got hurt working with split rim wheels, and many did.
โApr-11-2021 02:56 PM
โApr-11-2021 10:49 AM
I'm betting he didn't follow the proper steps for performing the stunt...Did he say "Hold my beer" first or not?
โApr-07-2021 07:53 PM
โApr-05-2021 05:42 PM
Grit dog wrote:
The chance it sitting flat, stationary, did any damage is really small, not worth buying a tire if it's only 2 years old. That's just silly.
And no, you cant replace the stem without breaking a bead, although only need to break 1 bead and it doesn't need to go over the rim, so pretty easy driveway fix with a jack, wood block, and your trailer hitch on your truck.
Unless you replace it with a Colby valve, which are really handy, although quite expensive and IMO, better reserved for emergency repairs.
โApr-05-2021 04:01 PM
โMar-27-2021 02:06 PM
โJan-20-2021 05:18 PM
mkirsch wrote:Bobbo wrote:Diamond c wrote:
Bobby I call B S on that!
Your refusal to believe does not make it false. Try it sometime.
I agree with the follow on post that says once the ratchet strap has the bead seated, you must put in some air before removing the strap.
Your definition of "seating" the bead differs from what is commonly accepted.
A bead is considered seated when it is pushed out tight against the outermost ridge of the rim, all the way around, on both sides.
There is no way for a strap to achieve that. A strap will push the tire's bead out to the step on the rim, cutting off airflow so you can inflate the tire and seat the bead, but it does not in and of itself "seat" the bead.
By the way, I did not have any issue seating the bead. All I had to do was lift up slightly on the tire and apply air.
โJan-20-2021 07:49 AM
โJan-18-2021 03:58 PM
