โOct-22-2019 08:02 AM
โOct-24-2019 08:59 AM
valhalla360 wrote:
...if it's important, it's a simple solution...
โOct-24-2019 08:26 AM
โOct-24-2019 07:16 AM
โOct-23-2019 11:20 PM
Grit dog wrote:valhalla360 wrote:
When you sign the papers, simply add a note that the tires shall be model XXXXXXXXXXX or as approved by the buyer with a manufacture date no older than X months from the date of delivery.
If it shows up with different tires, point to the clause and tell them to fix it.
ROFL.
Iโm not even a car salesman, but if I was Iโd tell you to pound sand on a request like that, unless I added the $ to your bill to cover a new set of tires....just because.
โOct-23-2019 12:27 PM
โOct-23-2019 10:59 AM
โOct-23-2019 10:25 AM
LosAngeles wrote:Any supplier is about the same. Choose the style best for your use and expectations.
Any recommendations for chains that wonโt break if I use them, but are cost effective? Also self tightening and easy to install.
โOct-23-2019 09:32 AM
LosAngeles wrote:
Any recommendations for chains that wonโt break if I use them...
โOct-23-2019 08:56 AM
โOct-23-2019 04:54 AM
OP wrote:
I'm about to custom order a 2020 F350 4 x 4 and according to Ford the tires included are: LT275/70Rx18E BSW A/T. These are to get the E load rating on the tires needed to get 11,500 GVWR.
โOct-22-2019 11:00 PM
โOct-22-2019 05:01 PM
โOct-22-2019 01:15 PM
Grit dog wrote:
LA, how do you sleep at night worrying about this stuff??
Get your truck, where you live you will not want, wish for or need chains unless you're trying to rip up a snomachine trail with a foot of packed snow on it.
You could have d@mn near bald tires and since you're planning on carrying around 3klbs of dead weight all winter in the bed, you will get about as good of traction as physically possible.
Yes, you can buy waaaay better traction tires for mud, ice, snow than whatever will show up on most any new truck. That is a given, save for special edition type trucks that actually come with tires that people WANT to have. The rest are mediocre, typically value line tires, however they are sufficient for most purposes, at least through the first half of their treadlife.
If you do feel the need for more snow/ice traction, take the OE tires, whatever they are and go have them siped as deep as the shop will sipe them (.5" is usually max). That will turn a mediocre set of ht/at type tires into good snow and ice tires.
โOct-22-2019 01:00 PM
โOct-22-2019 12:53 PM
Grit dog wrote:
...where you live you will not want, wish for or need chains...
