towing capacity 2001 GMC Yukon XL 8.1 liter engine
zell66
this will probably start a fire storm but I need to know some information. I'm looking at buying a 2001 GMC Yukon XL suburban 2500. it has a rear axle of 3.73. And what I can find online towing capacity is around 10,500 pounds. my question is in reality what is the potential towing capacity of this vehicle? I only tow about 2,000 miles a year generally flat terrain no mountains. I currently have a 1995 3/4 ton suburban with a 7.4. The trailer we just purchased is a 96 Jaco 37.5 foot with a dry weight of 10,000 pounds. I have a family of 6 and do not drive it enough to justify a diesel and this is a hell of a deal on this you can. My other options would be a Ford Excursion with a v10 but I would be going backwards in fuel economy. not that my current vehicle does any better at around 10 miles to the gallon towing
26 REPLIES 26
PAThwacker
The tire and loading sticker is on the door frame. The other axle rating sticker is on the door.
2015 Keystone Springdale Summerland 257rl
Tow vehicle: 2003 GMC K1500 ext lb
Previous: 14 years of 3 popups and a hybrid tt
PAThwacker
our 2004 sub 6.0 k2500
payload 2391
options
lt, sunroof, bose, leather, center buckets, g80
APT
2100 pounds for a 2006 8.1L 4WD. It's still more than a comparable Excursion.
2017 Subaru Outback 3.6R
BenK
APT wrote:
krobbe wrote:
The 3/4ton Suburban has over 1000# more payload than the Excursion.
2003 Suburban 3/4-Ton 2WD 8.1L(496ci)V-8 CurbWt:5620#, GVWR:8600#, Payload:2980#
That is just not accurate. Payloads for 8.1L 3/4 ton 5WD isright aroudn 2000 pounds. 2WD adds 300 pounds. 2980 might be a stripper 2WD 6.0L, but that big block is heavy.
Why always recommend going out and actually weighing your setup, axle
by axle. Both empty and fully loaded. As the only way to *KNOW* where
you are in reference to the ratings
Think about it...the options matrix is huge and these labels would then
have huge numbers of *DIFFERENT* payloads
One for the AC option. Another for 4x4. Another for power door locks
Another for power window. Another for automatic. Another for upgrade
interior. Another for upgrade exterior. Another for 2nd and 3rd row
seats. etc etc etc....then one with the combined AC & 4x4...then the
huge ETC for the multiplexing of all of the above or option combo
possibilities
Then the other stuff folks load into and onto their TV's and
trailers...multiplexed with the above multiplexed label listings
They have to use the 'curb' and so many have no clue what that is
Here is a link to a thread where try to explain how it works and an
example is my Sub's simple math using the curb (link shows my last
smog test data sheet that lists the 'curb' for my 7.4L 2500, which
is the data from GM (all OEM's provide their curb to all DMV's for
this testing and other usage requiring a 'curb' number)
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27214737/srt/pa/pging/1/page/2.cfm
BenK wrote:
So according to how most folks 'think' it works...taking the GVWR of
8,600 minus the curb of 5,250 = 3,350 lb payload or cargo capacity or
rating
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
krobbe
APT - According to automobile-catalog.com the payload on the 2wd 6.0L is 3080#. That's where I pulled these numbers from.
Me'62, DW'67, DS'04, DD'07
'03 Chevy Suburban 2500LT 4WD Vortec8.1L 4L85-E 3.73 CurtClassV
'09 BulletPremier295BHS 33'4" 7200#Loaded 1100#Tongue Equal-i-zerHitch Tires:Kumho857
Pics
APT
krobbe
2003 Excursion XLT 2WD 6.8L(412ci)V-10 CurbWt:6735#, GVWR:8600#, Payload:1865#
The V10 410ci Excursion has 310hp@4250rpm and 425ft-lb Torq@3250rpm.
The 8.1L 496ci Suburban has 340hp@4200rpm and 455ft-lb Torq@3200rpm.
There's no replacement for displacement. ๐Ÿ˜‰
Pics
APT
Considering your short towing distance, I would keep what you got unless you just want to replace it. And if you want to replace it, find a 3/4 or 1-ton pickup with 8.1L, V10, or diesel and take your other most fuel efficient vehicle for passengers .
BurbMan
APT makes a good point...I would not be a fan of 2 vehicles either, since we always had a lot of fun traveling as a family. But if you are staying local at under 2 hrs, wouldn't be the worst thing. The newer generation of burbs is much improved over the 90's generation in may ways, but the 8600 lb GVWR and basic tow ratings are pretty much the same. No question an 8.1 burb would tow the trailer better than than your 95 but it's still not the whole solution to the weight issue. Good luck and post back as to what you decide to do.,
BenK
Wanted to order full sized van, but no one offers a 4x4
After market wasn't good at that t ime, so ordered the next best...my K3500 Sub
Girls are gone, but a crop of nephew's n grandkids are here...so my Sub continues to be the main RV till they get their own
One nephew has a CTD crew 4x4, but with the second kid...noodling a HARD bed cap vs his current soft cap
So totally understand your plight
Good luck !
Via SmartPhone...excuse  the fat finger typos!
zell66
My last TT was a 30' and my current burban pulled it like a dream. Hate the idea of taking two vehicles. looks like I have some decisions to make over the winter.
BurbMan
I hear ya about the diesel....the V10 Excursion has its own set of issues, the numbers actually work out worse because it's a lot heavier than the Sub but it will get the job done almost as well as the Sub will. Good to know it tows OK now, but remember that will change when you load the trailer and pack the family in the truck.
Your other option if you don't need 4WD is a 350 or 3500 full size van. Will give you more room than a Sub and they make excellent tow vehicles. Something like this one.
If you really want to go for the burb, put the youngest kids in the way back seat to minimize the load back there, and pack the trailer to manage tongue weight. By manage I don't mean minimize because a trailer too light on the tongue will sway. You want to be over 10% but not by much....pack the trailer and run it over to the scales and see where you stand. Keep the brakes on the trailer dialed up....
zell66
we travel maybe 50 or 60 miles one way right now. We are blessed with MANY campgrounds and state and county parks close by and mostly all on water.
Dadoffourgirls
The Excursion has less payload than 2500 Suburban. You are at a max. Might be able to squeeze into 1 ton van, but not sure that they have tow rating.
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
