โApr-30-2013 06:39 AM
โMay-04-2013 03:28 PM
chuckftboy wrote:
It seems propane really confuses some people. LP actually stands for Liquid Propane not Low pressure. The extend a stay installs between the shut off valve and the regulator on the on board tank. When connecting the grill the hose simply feeds from the on board tank to the regulator on the grill but this is not low pressure gas, it is tank pressure, maybe 120 psi on a hot day. The only "low pressure" is after a regulator around 11.3 psi.
โMay-04-2013 01:20 PM
โMay-04-2013 08:42 AM
allen8106 wrote:Cecilt wrote:
My RVQ is getting a little worn and I have a Weber 120Q in the basement that I could easily use. However, I refuse to use those green bottles. We camp every weekend and I use the BBQ everynight so using the built in propane hose that attaches to my RVQ is very convieneint.
With that said, can I outfit the Weber to accept the RV connector. Do I need to remove the Weber's regulator? Where do I get the parts and is it a simple DIY. tks
The hose noted at the link below will work. It's the same one I use for my Weber Q220.
http://www.gandermountain.com/modperl/product/details.cgi?pdesc=Mr-Heater-5-Propane-Hose/Regulator-Assembly-F273710&i=447302&str=propane+hose&merchID=4005
โMay-04-2013 07:11 AM
โMay-04-2013 05:44 AM
Pineapple Kid wrote:
The Weber's in Europe work on the European campgaz bottles at low pressure
( the gas lines are held to the fittings with screw clamps )
However ask Weber over in the USA and they say NO NO don't take the regulator off it is dangerous??
They are both identical BBQ's
โMay-03-2013 10:22 PM
โMay-01-2013 06:59 PM
Jim & Betty wrote:Ron3rd wrote:
Here's how I did the conversion on my Weber Q:
Weber Conversion
BTW, like Jim posted above, some members have left the regulator on and are satisfied with the performance. Some members have reported lower flame and BTU outlet with the regulator on and claim the bbq does not get as hot. The fitting to replace the regulator was so cheap I went that route.
I should add something here about the lower flame I do think that does happen but it does not bother my cooking. I do ribs, steak, tri-tip and burgers and dogs. The reason I know that the flame is just slightly or appears to be less is I have a Weber on the porch and it is using the 20 lbs cylinder. But even with that the flame is still low.
Heck I am ready to BBQ you bring the beer.
JimR
โMay-01-2013 06:42 PM
Weber Conversion
Thanks for the additional information. Maybe it's hard to tell from the picture but the Calore part 401153 looks like something screws into it. If I remove the regulator from the Weber I will need a fitting that screws onto the threaded metal pipe. tks
โMay-01-2013 06:29 PM
Weber Conversion
โMay-01-2013 11:46 AM
Weber Conversion
โMay-01-2013 05:35 AM
โApr-30-2013 11:04 PM
โApr-30-2013 09:19 PM
โApr-30-2013 07:19 PM
PenMan wrote:Cecilt wrote:Tachdriver wrote:
I had the sidekick grill with a QD adaptor connected to a hose which was QD'ed to the trailer fitting.
My TT had the two bottles, the regulator going to the QD fitting. When I replaced the grill I removed the fitting from the sidekick and installed it on the weber, and yes I had to remove the regulator, it works and is hot as I need it.
If you have a class "A" or "C" you may need other fittings that I am not familiar with.
Others mentioned getting a small propane bottle but that defeats the purpose of using your 60-150 pounds of propane you are carrying around. Too bad I didn't take pictures.
This sounds like the plan. I currently have the quick connect attached to the propone hose that I pull out of the TT wall to connect to my Sunbeam Sidekick grill. So all I have to do is remove the male fitting from the Sidekick, remove the regulator from the Weber and screw the male connector onto the Weber and call it a day??? Sounds too easy? Have to missing something or more importantly a part. If so, I'll pick up a stand for the Weber and I'll be good to go.
This will do the trick. Since you already have the fitting from the Sidekick you don't need to buy anything (except the stand if desired).
