Valve Stems
lawnspecialties
These do not look like metal valve stems to me. I just noticed it tonight. I was preparing to pump the pressures up on the G614s since the dealer only put 70-80 psi per wheel.
Am I correct or is this a type of metal stem I'm not used to. Or is this the reason the dealer did not pump the tires up to 110?
24 REPLIES 24
JIMNLIN
Mikes correct.
the stem in the picture is a high pressure rubber snap in rated up to 100 psi. They come OEM on 3/4 and one ton DRW trucks and trailers with load E tires .
BB_TX
I am not ruling out that those are metal valve stems. They do have a metal stem protruding from the rubber base. They are certainly not the typical rubber stems.
rexlion
The stem in the picture looks to me like a high pressure valve stem. They are not all metal, strictly speaking, but they are tougher than the standard passenger vehicle's rubber valve stem. A tire shop can tell you for certain, but I think that stem may be good only for pressures below either 80 or 100 psi, depending on the exact stem this is. (Which is close, but not quite what you want.)
Have a look at this page: Tire Rack tech page
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
lawnspecialties
Happy Prospector wrote:
Those don't look like the metal stems I am familiar with, and the stems I have on my trailer would not fit on your wheels with the indention on your wheel where your valve stem fits. Are you sure your wheels are rated for 110 psi?
The information is out there, all you have to do is let it in.
Yes, they are rated for 110 psi and a load of 3750 lbs.
lawnspecialties
Thank you. Just wanted to confirm before I call them tomorrow. I am already supposed to call them to discuss why the Eqau-Flex brackets were screwed up. Like a thread from a month or two ago, two of the hangers on the back axle were pointing down. I just got that fixed tonight. That's when I noticed the valve stems.
Worst part of this whole thing is, I emailed the owner last week with two requests. 1. Leave the camper plumbing pressurized and don't winterize it since its getting so close to spring. 2. Make sure the tire shop installs metal stems in those wheels for the high pressures.
Happy_Prospecto
Kevin
Retired, Fulltime RV'er, 1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler, 2019 Polaris Ranger
Bob, the Yorkie Terrier helping me prospect til the money runs out
db7512
I vote for the not a metal stem.
2016 Newmar Ventana
2016 Ford Edge
Ranger_Smith
That is definitly NOT a metal stem.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
K_Charles
that is not a metal stem
coolbreeze01
Looks like a typical rubber stem to me.
2014 Sandsport 26FBSL
