โMar-20-2016 11:30 AM
โApr-11-2016 04:58 AM
โMar-23-2016 08:34 AM
โMar-22-2016 02:08 PM
tex wardfan wrote:
...can pressure build up in the system from a temperature change. That's all that's happened lately.
โMar-22-2016 11:59 AM
westend wrote:
I'd suggest to use a basin wrench on that fitting to make sure it's tight and secure.
A guy could assume that it wasn't tightened adequately when in manufacture and loosened from vibration. It will probably do the same with just a tightening by hand.
When you bring the trailer back to the dealer, have them tighten ALL the plumbing fittings. Since I don't trust anybody, I'd purposely loosen one to see if they got them all.
An alternative is to tighten them all yourself.
โMar-22-2016 07:49 AM
โMar-22-2016 05:17 AM
โMar-20-2016 04:03 PM
leeper wrote:
Take it back to selling dealer! What makes you think they did a pressure test. Do not try to fix it your self or you might void the warranty. To new to fix your self, could be more leaks.
โMar-20-2016 01:21 PM
โMar-20-2016 12:38 PM
โMar-20-2016 12:27 PM
wa8yxm wrote:
When I de-winterized for the 1st time I flooded the kitchen/living room area in this RV.. Turns out many RVers have a few loose nuts lying about (Also a few loose screws, like the ones holding the wires in the breaker box)..
One of those nuts was the compression fitting on a PEX line under the sink, the line pulled apart and flooded everything. I put it back together and tightened it down 10 years ago.. Did not touch it for 10 years.. Just re-did it (new kitchen faucet so I had to mess with it)
I'd check the pipes and make sure they are secure Wiggle them. Mine came out in my hand when I did that, Nut was not nearly tight enough.
โMar-20-2016 12:24 PM
John Wayne wrote:
Maybe it's not from the faucets, are there any places that water could be coming from the outside and leaking into the inside windows, vents, etc. have you had rain in the area since you parked it. Have you turned on the water pump to see if the water is coming from the Hot water connection?
โMar-20-2016 12:02 PM
โMar-20-2016 11:40 AM
