โMar-09-2020 02:27 PM
โMar-15-2020 12:18 PM
JIMNLIN wrote:That's a good suggestions that I will implement. Never did care for the quick connects. Will solder the joints and shrink wrap the wire connection. Will check my wire gauge at the same time.
Good ideas to work on.
Another is many trailer mfg use some type of clamshell wiring connectors. Over time and miles water corrodes those connections to the point proper amps doesn't reach the magnets even though a dwell meter says 12v.
When I was on the road and put a new or used trailer in service the first thing I did was R&R the brakes/bearings/suspension and removed all clamshell connectors and bad or smallish wiring. I soldered all joints and made them water proof as much as possible. This ensures full amps from the controller to all the brakes.
โMar-15-2020 11:46 AM
โMar-10-2020 11:55 AM
MitchF150 wrote:
Dunno on your trailer, but my 2019 Rockwood has auto adjusting brakes, which is new to me compared to my old 2003 Prowler..
On the drive home, it didn't seem to brake all that well. Raised my gain to 10, but only traveled about 5 miles home (yes, my dealer is only 5 miles from my house)
Read the manual for the axles/brakes and found that they are "auto adjusting". Kinda like drum brakes on older vehicles when you go in reverse and hit the brakes, they adjust on their own..
After my first long trip with the new Rockwood, I manually hit the brakes from time to time and found they were getting stronger and stronger and was able to reduce the gain on the BC.
Went on the next trip and did just normal braking, and all seems fine.
Again, just my experience with it on my rig.. I've not manually adjusted anything yet, but might check some things out before heading out this season, just to look on the new rigs setup, since it's all new to me too..
Good luck!
Mitch
โMar-10-2020 11:16 AM
Ironic you mention the self stripping electrical connectors because this weekend pulled the camper out from alongside the house and had no brakes.
It was that type of connector that failed.
โMar-10-2020 07:19 AM
SDcampowneroperator wrote:
Check the brake magnets with a magnetic compass to see if they are working. Simple test, pull the dynamite switch at the tongue then go to each wheel with your compass. is should point qiuickly at the wheel.
โMar-10-2020 07:18 AM
climb.on wrote:dodge guy wrote:
My 07 had a similar problem. My issue ended up being weak magnets in the brake assemblies! I replaced those and the braking was unbelievable!!!! Between the truck and trailer it would stop very well.
Just something else to check.
How did you determine that? Or did you just swap out the part and found it worked?
โMar-10-2020 05:38 AM
โMar-09-2020 11:15 PM
โMar-09-2020 11:02 PM
โMar-09-2020 09:35 PM
โMar-09-2020 09:01 PM
โMar-09-2020 08:50 PM
โMar-09-2020 07:42 PM
โMar-09-2020 06:42 PM
