Weight equalizer hitch
freealfin
I have read all about these (50+ sites) but I question their ability to transfer weight any different than a hitch bolted to the bumper frame if the ball distance to axle remains unchanged. Both make the frame behave as a single lever regardless to were they are mounted. You could mount a rear hitch with long non flexing arms to the front of the frame and still won't change a thing...a single lever is a single lever. I do see the load carrying and pulling improving simply because bolts are on shear and on a stronger anchor point. Please enlighten me with your thoughts and not by simply repeating what someone else said.
Thanks.
13 REPLIES 13
Hannibal
The spring bars are a linear extension of the truck's chassis that reach beyond the ball (lever point). The chains act as if you were pinching this extension toward the trailer's chassis to use the lever point to reverse the action of the tongue weight on the lever point. The lever point works both ways. If you pinch hard enough as in tightening the chains with stiff enough bars, you can lift the rear wheels of the truck off the ground.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
burningman
I think what you're not understanding is that with a weight distributing hitch, the trailer tongue is not just resting on the hitch ball like it is without one.
The spring bars of the WDH swivel left and right to allow turns but they don't freely swivel up and down. There is tension on them. They're trying to force the whole truck/trailer set into an arc as viewed from the side.
When you crest the top of a hill the WDH will not exert much pressure (or any if the angle is steep enough). When you approach a steep upward ramp, the hitch will be resisting the flex that puts on it.
They do transfer weight, mechanically. As others have shown, you can measure it on a scale.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
APT
There's this that many people seem to understand.
2017 Subaru Outback 3.6R
DustyR
I met a guy in Ocala, FL that towed a 32' TT from New Jersey without a WDH and said it was a little squirrely above 30 MPH. He felt he had no need for a fancy hitch. :h
2016 Open Range 319RLS
Tow Vehicle: 2008 Silverado 2500 HD
Duramax, Allison Transmission.
lightfoot
With all the responses/proof to the OP, we have not seen freealfin for a response. Interesting!
USN EN2
2012 Ford F250 SC, 6.7L TD
2015 Voltage 3200
2004 Honda GL1800 Reverse Trike
73guna
Ticket on the left, W.D. hitch bars unhooked.
Ticket on the right, W.D. hitch bars hooked.
Similar results as RinconVTR.
620lbs off drive axle.
400lbs added to steer axle.
200lbs added to trailer axle.
2007 Chevy Silverado Crewcab Duramax.
2016 Wildwood 31qbts.
BarneyS
You are forgetting about the rear axle acting as a fulcrum like a teeter-totter. BIG difference!
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Terryallan
3oaks wrote:
DutchmenSport wrote:
If you have doubts, try it. See what happens, and give us a report back.
I can only add. IF YOU LIVE thru it. Report back
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
RinconVTR
Thanks.
Pretty bold opinion having never tried a WDH before. And I will boldly tell you that you're entirely wrong.
Here is my exact, fully loaded situation, with a 960lb Tongue Weight on a short wheel base SUV with 1400lb bars.
720lb is transferred OFF the rear axle.
520lbs is transferred to the front axle.
200lbs is transferred to the trailer axles.
These are exact numbers directly off truck scale slip results.
Heavier, longer tow vehicle, and those with lower rated bars will not have the dramatic numbers I do, but I hope you get the point with such a dramatic example.
Walaby
You can decide to go with your analysis, or the input and analysis of all the folks from the 50+ sites you've visited. If you are not convinced by now, nothing, other than as Dutchman suggests, will convince you otherwise.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
3oaks
DutchmenSport
downtheroad
Very simply put:
Think of lifting a wheel barrow....the handles are similar to the spring bars of a WD hitch...they transfer some of the weight to the front wheel
You said you didn't want to hear what others have already said... but this is what others have already said...it explains it and it's the facts...
Weight Carrying
When you're towing a trailer with a standard rear-mounted hitch, your trailer's tongue weight is transferred to the rear axle of your tow vehicle. As a result, the back end of the vehicle may be forced lower and the front end raised. If this happens, your vehicle's rear axle will bear the weight of not only the trailer, but much of your tow vehicle's weight as well. Less weight on the front axle of your vehicle can cause diminished performance in terms of steering, traction and stopping power. It can also increase trailer sway. And your view of the road may be limited due to the awkward angle.
Weight Distributing
Before and after weight distribution
Weight distribution systems use spring bars to help combat the problems that often occur with standard hitch systems. Adding spring bars to your towing setup applies leverage to either side of your system, which transfers the load that is pushing down on the rear of your vehicle to all of the axles on both your tow vehicle and your trailer. This even distribution of weight results in a smooth, level ride, as well as the ability to tow at the maximum capacity of your hitch.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
