Why do I still look at my tankl level gauges?
opnspaces
Navigator
Navigator
I was just thinking about this. I know we are all familiar with stock tank level gauges not being accurate. On my trailer sometimes I push the button and the level looks right. And sometimes I push the button and know in my head that there is no way it's that full. So it brings up the questions?
Why do I press the button at all?
  • If the reading seems high I ignore it because these sensors all stink.
  • If the level seems about right I believe it. But then how do I know it's not actually wrong?
I guess my theory is that based on the way the sensors work it is safe to say they may read high, but they will never read low.
What's your theory, Am I on the right track or all full of p@@p?
21 REPLIES 21
wa8yxm
Figured out why you still look at gauges. My Fresh water still works after almost 15 years
DavidandDayle
Our grey tank gauge seems to be reasonably accurate. I dump both tanks at the same time. Only worry is if someone has been over-zealous dumping dishwater down the toilet.
On the last trip we were more worried about the readings on the propane tank. How does that work when it starts off only 80% full?
David and Dayle
opnspaces
Navigator
Navigator
Hook up a hose and macerator. I'm sure the garden department would appreciate the free fertilizer.
Lynnmor
importman wrote:
MrWizard wrote:
When i step on the toilet and it burps,
I know it's time to go dump
The water gauge works, and i can open a compartment door and visibly check the fresh water
That's what I do. Never been wrong.
So now you know it is full while staying overnight at Walmart, then should we do a Cousin' Eddie sewage drop?
importman
CavemanCharlie
Mine quit working completely . They don't even light up. I really don't care. I can open a compartment door and see the level of the fresh water tank. I can look down the toilet and see the level in the black water tank. And, as just a weekend camper I've never gotten the gray tank to full.
Oh, and, I have a gauge the I plug into an 12 volt outlet to tell me the voltage in the batteries.
Terryallan
philh wrote:
wildtoad wrote:
DSDP Don, I have to think if a 40 or more gallon black tank only lasts 2.5 days, you need to cut down on the beer. ??
I was thinking something similar. For two of us, 33 gallons is about 5 days.
My TT sleeps 10. I'm lucky to make 2 full days. Plus I have told them all to use plenty of water
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
philh
RobWNY
A very accurate way to determine when it's time.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
PastorCharlie
wa8yxm wrote:
Question: Do you go to Church?
related: Do you believe in Miracles?
You push the button to see if a Miracle has happened and the sensors are working as they should instead of as they do.. Of course they are not. but hey. Faith springs eternal they say.
Why the need to slam God and His children by comparing them to your cheap and broken black tank gauge?
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
TexasShadow
as stated above, we check the level of the FW tank.
TexasShadow
Holiday Rambler Endeavor LE/ 3126B Cat
Sometimes BMW K75 on Rear Carrier
Jeep Grand Cherokee or 2016 Ford XLT 4x4 super cab with 8 ft bed
M&G aux brake system
854 Watts of Solar Power
Always remember you're unique, just like everyone else.
Dick_B
I haven't been RVing for several months but I seem to remember that the Freshwater gauge might be `accurate' and maybe even the gray tank.
But the black tank is hopeless. I just go by the number of days we've been camping since the last dump. I think we can go a week.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
dodge_guy
I loved the ones on my first trailer. They were in 1/4 increments. Now they are in 1/3โ€™s. Sucks when you see 2/3โ€™s and all of a sudden full. At least with the 1/4โ€™s when I seen 3/4โ€™s I knew I was close.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
