โSep-22-2014 10:03 AM
โSep-23-2014 06:26 AM
wa8yxm wrote:
1: I have never heard of a quarter turn valve that is directional, but.. Possible it is
โSep-23-2014 06:20 AM
DE88ROX wrote:
I went out and looked. The bottom valve directional arrow is pointing towards the water heater and the top is pointing away. From the diagrams i have seen that is correct.
โSep-22-2014 10:58 PM
โSep-22-2014 07:55 PM
โSep-22-2014 06:35 PM
Harvard wrote:
Your hot water lines/taps will flow antifreeze via the bypass line/valve. It is not coming from the tank, is it?
โSep-22-2014 12:33 PM
darsben wrote:
Turn the cold one the other way or will it turn further? The handle may have been installed wrong by the dealer. IT IS A VERY LONG SHOT as I presume the water worked fine all summer
โSep-22-2014 11:14 AM
โSep-22-2014 11:13 AM
โSep-22-2014 10:55 AM
DE88ROX wrote:
This is my 3rd winter with the trailer so I've done it before and had no issues. The white Pex valves in the pic were new last spring. Installed at the dealer because the cheap plastic/brass ones broke.
โSep-22-2014 10:36 AM
โSep-22-2014 10:33 AM
โSep-22-2014 10:28 AM
Dutch_12078 wrote:
I suspect one or both of the valves are installed backwards. Those Flair-It PEX valves are directional. The white valves should have the flow arrow pointing towards the heater for the bypass to work properly. Note that the hot water outlet valve will NOT turn off the hot water in this configuration with this type of valve.
Notice the arrow on the valve body:
โSep-22-2014 10:27 AM
โSep-22-2014 10:20 AM
