โDec-18-2017 12:45 PM
โDec-21-2017 03:01 AM
time2roll wrote:
I doubt it would run the home furnace anyway. 2000 would be marginal.
โDec-20-2017 05:38 PM
โDec-20-2017 03:30 PM
pianotuna wrote:
Rent one.
โDec-20-2017 06:22 AM
โDec-20-2017 06:16 AM
โDec-20-2017 04:10 AM
time2roll wrote:
I miss the EU1000 and I say grab the EF1000 while you can.
โDec-19-2017 06:53 PM
โDec-19-2017 06:47 PM
โDec-19-2017 06:18 PM
โDec-19-2017 05:40 PM
โDec-19-2017 05:29 PM
pianotuna wrote:
SoundGuy,
It might run the furnace for 30 minutes (Honda does a 10% overload for 30 minutes), but it would be pushing things VERY hard.
โDec-19-2017 05:02 PM
SoundGuy wrote:
So I had a chance to measure my house furnace with my Kill-a-Watt meter and with the burner going & fan running on 120 vac house power got the following readings -
PF 0.61
VA 751
Watts 460
Amps 6.0
The little Yamaha EF1000iS is peak rated @ 1000 watts, continuous rated @ 900 watts, and 900 VA when the load PF is 1.0 ... but with the furnace having a PF of 0.61 the best the genset could provide would be 549 VA. Hmmmm, that's not gonna work if the furnace requires 751 VA. Nuts. ๐
โDec-19-2017 01:33 PM
SoundGuy wrote:pianotuna wrote:
1000 va may not be enough to run the furnace.SoundGuy wrote:
Back when I owned an EU2000i I re-wired the house furnace so I could run it directly from the genset sitting in the backyard. Max power draw measured with the furnace running was ~ 550 watts, I don't recall PF as measured with my Kill-a-Watt meter but I seem to recall VA was ~ 750 VA.
PF 0.61
VA 751
Watts 460
Amps 6.0
โDec-19-2017 12:08 PM
โDec-19-2017 05:18 AM
