'02 Adventurer Basement air
josslund
I'm out in the RV and my basement air/heat pump won't come on. Checked all the fuses and circuit breakers on the coach. Is there one on the unit itself? fan comes on. thermostat does not seem to be working, as nothing is showing on the LED for temp. Any thoughts from the community?
John and Lisa
2019 Tiffin 33AA
'20 Ford Escape Hybrid
3 REPLIES 3
tenn_vol_
I have a 02 Adventure, and you are going to have to get
power to the thermostat FIRST. I have had no trouble
with my basement air, cept early on the thermostat would
not pick up the second compressor sometime. tenn.......
DancinCampers
There should be a small fuse inside the tstat. 2 amp I think.
Dan & Sharon (Kasey, Our Yorkie, RIP 9Jan'05-26Jul'17)
2012 Winnebago Journey 36M
2020 Chevy Equinox, Blue Ox Aventa II, Air Force One
If You Obey All The Rules, You Miss All The Fun
Joe417
If you'll post the model number for both the heatpump and thermostat the guys can give you accurate troubleshooting help. Otherwise it's just guessing.
I'd guess, if your thermostat is digital then it has a battery that needs replacing. You need power to the thermostat to close the relays.
Joe and Evelyn
