12 volt light fixture problem
davent1946
I left a 2 bulb wall fixture on when I left the rig. When I returned, the fixture was off. I checked the bulbs in other fixtures, and both were burnt out. I attempted to replaced with new bulbs. With the push button switch still on, when I would insert the new bulb in either socket, the remaining lights on the circuit would fade to off. I removed the fixture from the wall, removed the switch and checked it and the fixture for continuity. Both were okay. I checked voltage on the line and it is okay. The fuse was not blown. All other light fixtures on the circuit work correctly. So, my question is, fixture or wiring or something else?
7 REPLIES 7
gatorcq
Is this a dual 12 volt light fixture?If yes I would also check the wiring as a bad connections can cause the dimming.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
davent1946
Both bulbs were burnt out when I returned. I confirmed that by trying each in another fixture. New bulbs are the same model #1141 bayonet
base. I tried both new bulbs in other fixtures, both worked. Hope additional info helps. Thanks for the replies.
enblethen
I believe OP has the wrong lamps. When he installs the new lamp, it shorts the circuit together causing the other lights to dim, but not enough to cause the fuse to blow.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MEXICOWANDERER
One bulb left on, then find ALL bulbs burned out?
A fundamental mistake is being made here. You need to check VOLTAGE across the lamp feed wires at the same time all lamps are switched on. These symptoms do not jibe.
donn0128
Dead battery?
Jim_Cindy
Some 12v and 120v bulbs look the same. Make sure they are 12v first.
Try 2 different bulbs, one could be defective.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison :C
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
enblethen
Wrong style of lamp!
Look in the socket see if it has one or two small round contacts. Compare it to the new lamps.
Bud
USAF Retired
Pace Arrow
