Adjustable Battery Charger
MM49
โ€ขTemperature compensated with control limits
โ€ขSCR Regulation โ€“ Charger provides a constant current and constant voltage charge as well as an excellent AC line regulation for precise control.
โ€ขSelectable Float Voltage โ€“ Allows battery voltage to be precisely set to the battery manufacturer specifications, within 0.10 of a volt.
โ€ขPositive Voltage Setting โ€“ Select only the voltage setting. No other setting required. If preferred, voltage can be pre-set at the factory.
โ€ขExternal Temperature Probe โ€“ Charger will monitor the exact battery temperature, which prolongs battery life and reduces maintenance caused by excessive heat and water loss.
โ€ขDual Input Voltage โ€“ Charger has been designed for either 115 or 230 volts AC.
โ€ขTransient Protection โ€“ AC input and DC output have surge protection
โ€ขBattery Types โ€“ All maintenance-free cells, lead acid cells, and nickel cadmium cells
Battery Charger
13 REPLIES 13
NinerBikes
Vulcan Rider wrote:
MEXICOWANDERER wrote:
Look...
MANUAL CHARGERS ONLY were successfully used for like nine decades with lead acid batteries.
Jeez have mental powers actually degenerated to the point where folks need keepers?
I am looking.
Those chargers were not adjustable.
And yes many folks DO need keepers.
It is only partially about "mental powers".
The other and possibly more important part is about training and experience. When you spend all of your free time in front of a TV or video game, that leaves little time to study and experience things that really matter.
I can sum it up in 4 words. "You can't fix stupid".
Vulcan_Rider
Look...
I am looking.
landyacht318
El Randero once tried to tell me 2 depleted group 31 plTP AGM batteries could not accept more than 75 amps, when a 100 amp model was ordered.
When the real 100 amp 'boondocker' arrived, which was physically larger to boot, surprise! They could accept over 90amps, and could for close to an hour before tapering began.
If I wanted smoke blown up my A$S I'd get a cigar and a garden hose.
Trust if you want to, but believe only after verification.
You want a Powermax, skip Randy, go right to Errin @PM, and tell him what Absorption voltage you want, if not 14.4.
Dont try and ask for a digital timer though.
MEXICOWANDERER
What's wrong with a Randyized Boondocker charger plus a Megawatt?
time2roll
Single voltage manual charger is lame for RV use even if temp compensated.
Fairly low output to boot.
MEXICOWANDERER
It's a Plug-N-Play life now. Virtual reality physics and chemistry. Got cancer? Press that button repeatedly until it goes away. Got noisy neighbors? Insert credit card into slot on power post, press button and they go away. Don't want rain? Press the channel selector button until you find a meterologist with a kinder gentler forecast.
azrving
Lmao. I have been tweeking that little screw on my power supply WHILE my convertor or charger were running too. The batteries cried, the little fans whirred away as we watched the 40 inch led with the heat on 70. I'm waiting for a knock on the door and hand cuffs. Battery abuser....... but sir, I paid for the batteries and I didn't want to run my $2,300 generator a long time and have to listen to it. WE DONT CARE!!!! You will not go over 14.4 v OR IT's JAIL TIME FOR YOU!!!!!
The supreme council says NO MANUAL CHARGERS.
MM49
This would be an inexpensive charger for a Li-ion battery bank.
MM49
MEXICOWANDERER
Look...
MANUAL CHARGERS ONLY were successfully used for like nine decades with lead acid batteries. Note the word successfully. It has meaning.
Maybe our ancestors were more intelligent than some folks posting on this forum. Flick your wrist on the steering wheel on a 2-lane road and a grater-like Peterbilt radiator grill may fricassee it's way back to your rear axle. Or step out your door wrong and end up in a body cast for six-months.
We all wish and pray that today's RV'er does not have fourteen too many brewskies and boil batteries to explosion. Jeez have mental powers actually degenerated to the point where folks need keepers? "Hey Harry, don't lick the receptacle!"
God forbid. Ten tons hurtling down the road powered by a skull enclosing 25" of vacuum.`
I give up...
Vulcan_Rider
This is NOT a consumer product.
Overkill price and feature wise and downright dangerous to the battery.....and maybe the operator if not used correctly, which is likely in my opinion.
Bill_Diana
MEXICOWANDERER
A lot like a Rolls Royce ad.
If you need to ask, you can't afford it. Bet the cheapest charger there is >$450 and a hundred twenty amp charger would be worth the same as a home living-room furniture ensemble. And I don't mean "You'll Love It At Leavitt" quality.
Bill_Diana
